Replace Cluster Lense
Old Jun 28, 2016 | 01:02 PM
steven92's Avatar
steven92
Has anyone here replaced or know how to replace the instrument cluster lense? The previous owner must have dusted it with steel wool, it's all scratched and a replacement is under $30. Part #3 in the diagram
Old Jun 28, 2016 | 01:29 PM
Don't know if there's any way to just pry it out and replace, but here's the 2009 FSM, click on the IP folder and scroll, if you do have to remove the cluster is sounds like a royal PITA. If you need a new year just click on Parent Directory and select year.
Index of /FSM/G37/Coupe/2009
Old Jun 28, 2016 | 10:28 PM
reNeglect's Avatar
reNeglect
Next option would be to get a custom cut out of clear vinyl, and install it on top of the lense like a screen protector on phone. I use to work at the mall doing this sort of thing, the clear wet install film fills in the scratches and makes it look brand new.
Old Jun 29, 2016 | 10:03 AM
nogoer's Avatar
nogoer
what about using one of those headlight restorer kits? The ones where you use a drill and progressively lighter sand paper?
I have a feeling that even if you get the cluster out that the lens is prob glued somehow to the binnacle itself and would require some surgeon like precision to replace without Fing up your gauges.
Old Jun 29, 2016 | 12:49 PM
The fact that they sell the replacement cover would seem like it would be something that could be R&R'd without too much trouble, but the million dollar question is how ????
Old Jun 29, 2016 | 12:52 PM
reNeglect's Avatar
reNeglect
I've taken apart my old Altima before, the cluster is not glued on. They are just clips holding it in.
Old Jun 29, 2016 | 01:27 PM
j50ny's Avatar
j50ny
I think it's just clips. However, try reaching out to botlfed98. He had a listing in the FS section for a modified gauge cluster. Probably knows how to remove it quickly and easily.
Old Jun 29, 2016 | 01:41 PM
steven92's Avatar
steven92
this sounds really complicated. I'll try a headlight restorer and see how it goes from there
Old Jun 29, 2016 | 01:43 PM
reNeglect's Avatar
reNeglect
Probably not the best idea to wet sand inside the cabin..
Old Jun 29, 2016 | 05:14 PM
steven92's Avatar
steven92
I was going to use rubbing compound or Meguires PlastX
Old Jun 29, 2016 | 07:19 PM
Kris9884's Avatar
Kris9884
Yeah I would try PlastX, it worked wonders on my last headlights and they were made of much harder plastic.
Old Jul 2, 2016 | 01:50 AM
hurleyguys's Avatar
hurleyguys
well i have done it to my old g35. there were water spots on the lens and it finally bugged me enough to remove it and polish it out. i just used normal clear coat polish and wax. you are gonna have to do it by hand (which is a pain). came out great. you prob wont have to sand it unless the scratches are really bad.
also couldnt hurt to just try to polish first cause i am sure you have some in your garage anyway. before you replace.
OfficialG
Dec 17, 2016 11:40 PM
ZzirGhozaif
Dec 16, 2016 07:18 AM
GrayG37
Sep 1, 2016 08:50 AM
iBRONXIE
Jun 29, 2016 01:10 AM
