Need help please, Paint and Wheels Stained
Old Jun 2, 2016 | 04:56 PM
JUMBO PALACE's Avatar
JUMBO PALACE
Hi guys. To add to my recent bad luck with the wayward tire tread hitting me I'm having some paint problems. I brought my car in for a service and rotation. When I got it back I took it home and noticed there was some sticky stuff on the wheels. I couldn't get it off completely using soap or goo gone. The wheels are clear coated so I tried non-abrasive compound. Nothing. Tried clay bar on the paint. Nothing. What I thought was dirt on the paint is the same stuff apparently. I think the tech run over something while checking my brakes (which I did ask them to look at) but I can't prove anything because I drove it home already. My local body shop said there wasn't anything he could do to clean up the wheels. Does anyone have any ideas. I'm so upset by this Really tired of things that aren't my fault becoming my problem.
Old Jun 2, 2016 | 05:41 PM
Autocutter's Avatar
Autocutter
If the coated surface is smooth you may want to try some 90% medical alcohol from the drug store. If it's not smooth then the substance merged into the clear coat. The stain does look to be petroleum based.
Old Jun 2, 2016 | 08:12 PM
slartibartfast's Avatar
slartibartfast
Try a little WD40. If that dissolves it, you can then finish off with soap and water.
Old Jun 2, 2016 | 08:51 PM
JUMBO PALACE
Thanks for the suggestions guys. The wheels have clear coat as well. Alcohol and wd 40 are safe to use?
Old Jun 3, 2016 | 12:39 PM
Kris9884's Avatar
Kris9884
Absolutely, WD-40 is harmless on paint but be sure to clean it off very well and re wax or it'll leave a dull shine to it.
Old Jun 8, 2016 | 05:00 PM
saywat?'s Avatar
saywat?
compound polish might help
Old Jun 11, 2016 | 12:09 PM
RadioFlyer's Avatar
RadioFlyer
You can also try bug and tar remover. It's the only thing that gets off certain stuff.
Old Jun 11, 2016 | 12:11 PM
Did you ever figure out a fix for the wheels Jumbo? I'm assuming the wd-40 should've worked hopefully!
Old Jun 11, 2016 | 12:46 PM
Roadrash666's Avatar
Roadrash666
Try some Iron-X
Old Jun 14, 2016 | 09:22 AM
JUMBO PALACE
I've actually been super busy and so haven't had a chance to try. The initial shock and rage wore off so it's faded to a dull anxiety that's easier to ignore LOL. I'm gonna try the WD-40 relatively soon. As long as I soap and water wash the area afterwards I won't do any damage correct? I'm very leary about putting things on my paint/finish that I've never put there before.
And I did try bug and tar remover, thanks for the suggestion though Radio
Old Jun 14, 2016 | 09:23 AM
JUMBO PALACE
Originally Posted by Roadrash666
Try some Iron-X
If the WD40 doesn't work out I'll try this next. I have some rail dust on my rear near the Fuji symbol I wanted to get rid of anyway.
Old Jun 15, 2016 | 01:51 PM
Kris9884's Avatar
Kris9884
WD-40 is completely harmless to paint, they state that very clearly on their website. Downside is it can also clean off the wax if you have any so you'll need to re-wax that area.
http://wd40.com/uses-tips/automotive/all
Old Jun 16, 2016 | 01:50 PM
JUMBO PALACE
Protect Car Paint & Polish Chrome - WD-40 Uses & Tips
Ahh I see! I wasn't sure what you meant by needing to re-wax to avoid a dull shine. Thanks again for the help guys.
Old Jun 16, 2016 | 04:12 PM
Kris9884's Avatar
Kris9884
My bad, that was pretty vague
Old Jun 17, 2016 | 09:20 AM
supreme's Avatar
supreme
Meguires Ultimate Compond has always worked wonders for me. Rub it HARD. Like you are trying to rub the paint off. Give that one a shot. You can find it at your local walmart.
