Any way I can fix one of my parking lights?
So one of my parking lights isn't working. I replaced the bulb but still not working. Fuse maybe?
Originally Posted by Epiphany
Did you replace it with an LED bulb? Rotate the bulb to change the polarity if it's LED.
Originally Posted by xmajd92
Will try again after work.
I tried it and it worked. Then later on the bulb shut off on me again. I reopened the area and realized that it turns back on when the wiring is positioned a certain way. Is there anyway to remedy this issue? Because I can't keep the wiring from moving inside the housing. Why would the wiring be faulty if I have never touched that area before swapping the bulb?
Originally Posted by Kris9884
Couldn't tell ya how it happened but the best way to fix it is to isolate which wire it is, cut it, strip just a little bit of casing and slip it back into the harness plug or solder it to the metal connection, whichever it ends up being. Or if its easier for you just cut the whole plug off and solder and shrink wrap another plug in place. It'll be like new.
