help headlight problem
Old Nov 13, 2015 | 12:52 PM
G37Ghost136's Avatar
G37Ghost136
My passenger headlight is not working I check the fuse and everything its okay the passenger signal works the fog light also works that headlight I change the bulb and still not working any ideas please help
Old Nov 13, 2015 | 01:38 PM
BurtoN86's Avatar
BurtoN86
HID headlights? If so, it's likely the ballast
Old Dec 10, 2015 | 07:57 PM
LGmobile's Avatar
LGmobile
Remove the fender liner, the ballast power plug is underneath the headlight.
Disconnect that power plug and use a voltmeter or 12v led bulb to test if power is making its way to the headlight.
Sounds like a bad ballast/bulb.
You can have someone turn the lights on and just look at the projector. If it strobes/tries to start, that means the bulb is dead and not holding an arc therefore the ballast turns off the power to the bulb.
Ricio1991
Dec 10, 2015 08:12 PM
OfficialG
Dec 8, 2015 10:15 AM
samkon
Nov 12, 2015 07:12 PM
VictorCgotzon
Nov 12, 2015 02:40 AM
tscani
Nov 7, 2015 08:23 AM
