Issues with Diode Dynamics Turn As Tail Module + Resistors
Old Nov 1, 2015 | 02:31 PM
Carfanatic's Avatar
Carfanatic
Unhappy Issues with Diode Dynamics Turn As Tail Module + Resistors
Hi Everyone,
I saw the turn as tail mod and it seemed cool so i went ahead and purchased the modules with the resistor pack from them and this is what i've done,
G37 Wire Identification :
Green Solid wire = Indicator Halogen bulb wire
Green Wire with Stripe = LED Bulbs
Now Diode Dynamics sent the module where on side of the Module has two wires
Yellow ====== become a white wire
Red ======
Now it seems simple enough connect the Green to Yellow "from the harness and the red to the Green Striped wire. and then the White wire to the Green Striped wire thats going to the LED's.
So i try everything out and i experience Hyper Blink
Then i add the Resistors to the Green wire and connect the other end in the the Black , However still get Hyper Blink ....
Anyone here that can help me with this.....
Exhausted from searching forms and trying other wiring sequences ....
Car : Infiniti G37x Coupe 09
Thank You
Old Nov 1, 2015 | 03:25 PM
RxRyanM's Avatar
RxRyanM
You could, ya know, try calling or emailing Diode Dynamics. Nick seems to be incredibly helpful in all his posts on the board.
Old Nov 1, 2015 | 06:46 PM
telcoman's Avatar
telcoman
And measure the resistance with an ohm meter to be sure they are the correct value.
Telcoman
Old Nov 1, 2015 | 08:15 PM
timc00k's Avatar
timc00k
It appears to be a bad batch of modules that were sent out. Check this thread out as others are also experiencing "hyper blinking".
https://www.myg37.com/forums/g37-cou...nal-mod-4.html
Call DD tomorrow and get an RMA.
Old Nov 1, 2015 | 10:50 PM
beng37s's Avatar
beng37s
+1 on this
Old Nov 2, 2015 | 08:06 AM
Carfanatic's Avatar
Carfanatic
Can anyone explain where the resistor goes on our cars, I have a feeling I'm simply placing the resistor wrong ...
Old Nov 2, 2015 | 10:36 AM
JC-RH's Avatar
JC-RH
Check one of my previous posts. I had the same issue and got it sorted out.
Old Nov 2, 2015 | 02:08 PM
Abramite's Avatar
Abramite
The set I ordered was just a pre wired harness that was plug and play....
Old Dec 5, 2015 | 08:04 PM
bikezilla's Avatar
bikezilla
Just got and installed mine tonight.
The resistor is now part of the harness, 5 min installation each side.
Old Dec 6, 2015 | 01:04 PM
PongSanity's Avatar
PongSanity
Why didn't you buy the PnP kit instead? They have those for the coupe.
Old Dec 7, 2015 | 12:10 AM
runzgood's Avatar
runzgood
Not sure about your other connections / colors of wires, but the resistors connect between the tail light "hot" wires and a chassis ground. The purpose of the resistors is to add to the circuit load because changing from the incandescent turn signal bulb to the tail light LED's decreases the load and the car's electrical monitoring system thinks a bulb has burned out. (Same thing will happen if you change the front turn signal bulbs to LED's -- you'll need to add a resistor to a chassis ground on each side.)
Old Dec 7, 2015 | 10:52 AM
Diode Dynamics's Avatar
Diode Dynamics
One of the quickest, easiest ways to tell if the resistors are working correctly, is to feel them when the turn signal is in use. If they aren't getting hot than that's a red flag that they aren't installed correctly.
Heat is a byproduct of electrical resistance, if there's no heat, there's no electrical resistance being created.
Feel free to give us a call if you need any assistance: (314) 205-3033
Nick C.
Old Jan 20, 2018 | 09:32 PM
boroy1's Avatar
boroy1
Angry Diode dynamics turn as tail issues
Hello All,
I purchased the PNP for my G37 Convertible and the right tail light works great but when I plugged in the left tail light it did not work! So I thought that it was a bad module so I swapped them and the right tail light works and the left one still does not. I will call DD on Monday! Any thoughts????
Thanks, Rob
Old Jan 20, 2018 | 10:16 PM
PNW_IPL's Avatar
PNW_IPL
Originally Posted by boroy1
Hello All,
Thanks, Rob
installed mine last year. Plug N Play no issues.
Old Jan 21, 2018 | 06:54 PM
F13SC's Avatar
F13SC
I installed today and no problems, took me 5mins. PNP
