2014 Q60S - Rear Turn Signal Bulbs
Old Oct 6, 2015 | 02:35 PM
Tonewheel's Avatar
Tonewheel
Well, I thought this would be simple. Maybe not...
Received my LED upgrade rear turn signal lamps from DD today, only to find the 2014 does not have the same simple plug and play set up as prior years. Looks like the entire tail light assembly needs to be removed. So be it...
Anyone ever do this? Visibly, there appear to be three bolts/screws that need to be removed, and a number of what appear to be guide pins of some sort.
Any experienced comments are most welcome. I'm not going to attempt this without a knowledgable comment or three. Thanks!
Old Oct 6, 2015 | 03:40 PM
2008G-Man's Avatar
2008G-Man
There are some DIY threads out there for the tail lights. I don't subscribe to the "tap with a hammer" approach as I feel you could break the bolts back into the plastic. To remove mine I used the "pull like h3ll" method.
Old Oct 6, 2015 | 09:09 PM
OhGwhiz's Avatar
OhGwhiz
Tone I changed mine in the spring and I believe I loosened the screws and gently rocked the light assembly from the outside until it backed out of usual location. It was very straight forward after the first one. Take your time and good luck. Let us know how you make out.
Old Oct 10, 2015 | 09:59 AM
Tonewheel's Avatar
Tonewheel
Need some additional input here.
On the driver's side rear tail light assy, I removed the 3 bolts. The assy comes loose on the side closest to the center of the trunk, but the side closest to the fender won't budge. I checked around and found 2 additional securing points. It looks like these caps, or covers, (one brown and one white) may need to be pulled off before it will come loose?
Thoughts? Help!
Old Oct 10, 2015 | 10:36 AM
krazyfiend's Avatar
krazyfiend
I've removed my tails a lot over the past two years.. A simple rubber mallet and some sturdy taps on the back of the metal posts have never failed me nor harmed the housing. They do pop out so kind of hold on to them so nothing can scratch paint accidentally.
Disclaimer.. I take no responsibility if something does happen... Ambient temperature effects plastics greatly among other variables.
Old Oct 10, 2015 | 10:52 AM
Tonewheel's Avatar
Tonewheel
Here's a photo of the two secure points I'm referring to. They look like they need to be removed prior to pulling out the tail light assy?
G37XSLOLSEEYA
Dec 27, 2015 09:03 PM
tmmueller
Nov 3, 2015 07:24 PM
GFTW
Oct 12, 2015 04:50 PM
SheLLz
Oct 6, 2015 08:09 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
