Restored my headlights
Old Aug 20, 2015 | 05:38 PM
pal51961's Avatar
pal51961
3M makes an awsome kit that attaches to your drill. It uses several sanding pads, and a compound to make them look like brand new. I just did my wife's car and they look like new.
Old Aug 20, 2015 | 05:59 PM
twin_snails's Avatar
twin_snails
Originally Posted by twin_snails
^ I've heard that stuff (Blue Magic) is little more than WD-40. Is that true?
Bump on this question.
I did a DIY on for when I did my headlights a few months back. Gives a good idea for how much you need to wet sand them. Took photos at every grit stage to show the transition.
https://www.myg37.com/forums/d-i-y-i...storation.html
As Brad said, Gio's DIY is excellent and was the inspiration for me finally getting around to the restoration.
Old Sep 5, 2015 | 05:15 PM
cconklin2's Avatar
cconklin2
i used toothpaste. wish i would have saved the picture of before and after...
Old Sep 14, 2015 | 01:35 PM
Herostar's Avatar
Herostar
Originally Posted by -SnowMan-
Seal them with wax or a sealant and they'll be good for around a year.
Unfortunately when you sand them you remove the UV coating and they're prone to fogging up more easily. So it's really a maintenance thing you have to keep doing to keep them looking nice.
A solution to this issue is to have a uv-resistant clear-bra applied to the headlights. It will protect the finish you worked so hard to obtain, and if it gets damaged you can simply have it removed and a new piece applied.
2K1 6T8
Oct 6, 2015 07:40 PM
takeapieandrun
18
Sep 27, 2015 12:36 AM
Allboutcali
Sep 26, 2015 03:43 PM
pauliewalnutzz
Sep 8, 2015 11:41 AM
