Matte Graphite Window Trim??? Need Opinions
Old Jul 20, 2015 | 09:35 AM
  #61
Dnovz41's Avatar
Dnovz41
Originally Posted by Broski28
A little update on the grill. I did the slats in gloss black and planning on doing the outer trim in the matte gray. Although I am digging the midnight grill look
Nice work broski! You're going through the mental phases I did haha, midnight look is solid, I rocked it for about a month before I did my outside, lettering, and trim in brushed gunmetal
Old Jul 20, 2015 | 03:46 PM
  #62
Broski28's Avatar
Broski28
Thank you sir! For now I'm really feeling the chrome lol, I plan on ordering the gray soon and finishing it up tho. Thank you for the idea, it never even crossed my mind before but man does your's look good!
Old Jul 20, 2015 | 05:49 PM
  #63
Awgd8's Avatar
Awgd8
Do you just put the vinly wrap while the trim is installed or you have to remove the trim to do this? Same question with front grill?
Old Jul 20, 2015 | 06:54 PM
  #64
Don't remove the trim, getting it reinstalled would be a b*tch. Here's the DIY
https://www.myg37.com/forums/d-i-y-i...-g-sedans.html
My 09 grill I left on to place the vinyl initially then removed it for the rest of the install.
Old Jul 20, 2015 | 09:58 PM
  #65
Broski28's Avatar
Broski28
Like blnewt said, keep all the trim on including the grill.
His DIY is spot on! Lay a little, slide your finger along it to press it down while lightly pulling on the vinyl. Get it all down then start trimming and tucking
As for the grill, if you have a 10+ i found it really easy to lay it in strips. You'll need a some heat for the longest slats (the top and bottom ones) but the rest were a breeze. I don't have any tips on the outer trim for the grill because i haven't tried but same concept applies. Lay, heat and gently pull. You'll get the hang of it pretty quickly.
Old Jul 21, 2015 | 09:41 PM
  #66
Awgd8's Avatar
Awgd8
Thank you both for giving all these tips! I will try it some other time...
Old Jul 22, 2015 | 02:58 PM
  #67
Dnovz41's Avatar
Dnovz41
Thank you man! You did a really clean job on the inners, looks fantastic!
rob145
Mar 28, 2016 01:28 PM
Dillybar12
Nov 1, 2015 07:23 PM
Mattimus
Oct 4, 2015 01:33 PM
RexHavoc
Oct 2, 2015 11:47 AM
