Fog lights are...
Old Jan 22, 2015 | 01:09 PM
jomak123's Avatar
jomak123
Fog lights are...
2011 G37x Sedan. The data I have says they are H8, but when I search an auto part site it says H11. Are they the same? What is right?
I was looking at lights on ebay too and half the H8s say not compatible.
Old Jan 22, 2015 | 01:10 PM
G37Xtreme's Avatar
G37Xtreme
We have the same car. Mine are H8.
I see lots of bulbs being advertised as H8/H11 so maybe they are somewhat interchangeable? However, in doing a little research, I see that these bulbs are identical except 1 VERY important difference. The locking tabs. You can probably get an H8 to lock into an H11 socket (not sure) but the H11 has larger locking tabs and I doubt it would lock into an H8 housing.
http://www.jaguarforum.com/showthread.php?t=63712
Old Jan 22, 2015 | 01:34 PM
inspector94's Avatar
inspector94
Sedans are h8 and coupes are h11 starting 2011
Old Jan 22, 2015 | 04:33 PM
jomak123's Avatar
jomak123
Dam Infiniti for having a coupe and sedan with the same name!!!
Old Jan 24, 2015 | 09:29 AM
dragion's Avatar
dragion
H8 = H11
They are the same...both work.
How do I know...
I've tried both.
Old Jan 24, 2015 | 04:13 PM
EG Ryan's Avatar
EG Ryan
Originally Posted by dragion
H8 = H11
How do I know...
I've tried both.
Just for info -- H8 bulb is 35 watts while the H11 is a 55 watt bulb. The H11 bulb does put out more light than the H8.
If you mean you've used an H11 in your G, I guess the extra wattage drain that bulb takes did not blow your fuse, so it's all good.
I, personally, am going to try these led fog light bulbs:
H11 Philips LED bulb | H16 Philips LED bulb | H8 Philips LED Fog bulb
I know, expensive, but they put out almost twice as much light as an H8 halogen bulb and uses less than 10 watts.
Old Jan 24, 2015 | 06:56 PM
dragion's Avatar
dragion
Sorry, I was referring about HID bulbs, but all the same that they both work.
Old Jan 24, 2015 | 09:37 PM
inspector94
yea they are similar, like EG Ryan said they only differ in watts and slight locking tabs.
Old Jan 24, 2015 | 11:35 PM
jomak123's Avatar
jomak123
So if I buy a 50W Cree LED H8 it will not work???
Rayramg37
Nov 18, 2015 09:06 AM
tomro99
Nov 17, 2015 02:08 AM
Gefartenblatz
Nov 10, 2015 11:45 AM
pcwd
Sep 15, 2015 10:06 PM
CasperG37
Sep 14, 2015 07:46 PM
