Fogs on with parking lights
Is there a mod I can do to make the stock fogs on a 2010(the ones in the headlights) come on with just the parking lights? They only come on with the headlights.
I ask about something like this before. Not sure if it is what your looking for though.
KP Technologies
KP Technologies
Can I just cut the 2 wires from each...I assume 1 is power 1 is ground? Ground the 2 wires & tap the + wires into the parking light wires? I understand I'll loose the on/off switch but as long as the lights are on in any mode the fogs should be too & if they are off the fogs should be off as well.
Or will that screw something up? Never know these days with all the damn electronics in cars.
no I actually wired them right to the battery for the positive and the relay in the box so they will only come on with the parking lights. I didn't take pics
I can try to get some tomorrow I'm still at work and it'll be dark when I leave, But if you where to remove the cowl where the cabin filter is you'll see the main wire harness that leads the fuse box, its laterally in the fender
this is how i did it back in the day also.. did the B13 and 200sx ones..
would be nice to have it done on the G
some back in the day methods
All B15 Models Fog Light Mod
HOW TO: Fog Light Mod. Run Foglights Separate From Headlights. Use as DRL's. : Nissan Pathfinder Forum / Infiniti QX4 Forum
Fog Light Mod
tomro99
Nov 17, 2015 02:08 AM
