Help Installation Of GT-R Button
Old Oct 2, 2014 | 05:27 PM
Donnie's G37S's Avatar
Donnie's G37S
Well with all the info found with research. It Sounds simple.NOT.With wheel up and out no way to unclip wiring. under wheel i have a panel that i'm not sure how to remove. So now I'm stuck. Any suggestions would be great. Not sure if it has to do with my model.2012 G37S.
Old Oct 2, 2014 | 05:56 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Here's a mobile link, best I can do from my phone.
I have a 2012 G37S and I did it just like he shows, so it's not the car.
Old Oct 2, 2014 | 06:47 PM
Donnie's G37S
https://m.youtube.com/watch?v=VHHGMkFrPio
Did you remove the panel under the Steering wheel. How did you reach the clip.
Old Oct 2, 2014 | 08:54 PM
monytx's Avatar
monytx
Removing the panel helps a bit more. With a flat head screw driver you're able to get in there to release it.
Old Oct 3, 2014 | 07:11 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Steering wheel all the up. You will need a long, thin blade flat screwdriver. It takes some maneuvering but once you get the screwdriver to press in on the tab of the connector it will pop right off.
The whole swap took me less than 5 minutes. Really, the hardest part is finding the angle to pop the connector off.
Old Oct 9, 2014 | 04:03 PM
~Lefty~'s Avatar
~Lefty~
Yep, that's how I did it.
SS2006
Aug 27, 2024 07:33 PM
Lt8Che
91
Apr 8, 2022 04:55 PM
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
GeezerB
Aug 26, 2015 05:16 AM
cparise
Aug 19, 2015 01:51 PM
