Review Diode Dynamics Interior LEDs/1st Post
Old Sep 21, 2014 | 02:41 AM
G37zus's Avatar
G37zus
Turned out really good! How much did the lot run you? I've been contemplating going DD or piecing my own LED kit together through DDM.
Old Sep 21, 2014 | 10:14 AM
Redfire32's Avatar
Redfire32
Ginger ninja
Originally Posted by Mark It Zero
I figured now was a better time than ever to make my first post and join the forum. I've been lurking here since the beginning of May when I bought my first G37 (2012 Sedan), which I f******* love by the way. My first upgrade was an inexpensive one but completely changed the look of the interior and I couldn't be happier.
I order all of the SMD2 interior LEDs and license plate LEDs from Diode Dynamics a little over a week ago. I ended up calling to make sure I was getting the correct "stage" since I read on here that they were/are in the process of changing the way bulbs were listed. Nick (not sure which one, since I believe there are two) was a huge help and made sure that I was getting exactly what I wanted. The bulbs came in two days later and were packed/labeled really well. Total install time was about 30 mins (should've been 20 or less), only because one of the license plate light housing got snagged and I wanted to make sure I didn't damage anything.
Like I previously said, I couldn't be happier with their product/service. I'm in the process of deciding on which D2S, fogs, and all other exterior lights I should go with, but unless y'all have some different recommendations I'll most likely go with DD since I was so impressed by the way the interior lights turned out. The only complaint I have is the decal they sent me with the lights, it'll take up the entire back window lol. I'll work on a window decal for them and send it out for production
Mark it zero, have you ever installed this type of lighting before? I'm seeing your results (loving them btw) and reading it only took you 30 min.....Tell me plz, is this something a total rookie could accomplish in an hour? I've wanted a DD kit for what feels like forever but what keeps holding me back is the thought of myself inside my beloved G takin **** apart n not being able to put it back together or lord forbid breaking off a key piece of plastic.
Old Sep 22, 2014 | 11:32 AM
Diode Dynamics's Avatar
Diode Dynamics
It's extremely easy to install, probably the easiest mod you can do to your G FWIW
It's the same process as replacing your factory bulbs
Nick C.
Old Sep 24, 2014 | 09:59 AM
JT2014's Avatar
JT2014
Installed the map, door & trunk lights. A lot cheaper then where I used to buy them. But they seem to be about the same output.
Thanks
Old Sep 25, 2014 | 03:50 AM
Redfire32's Avatar
Redfire32
Ginger ninja
Nick C.
I was referring to the ease of installation of your interior lighting kit? Is this an easy install? Especially if it's someone who hasn't donr lighting changes on a vehicle ever before?
Old Sep 25, 2014 | 01:32 PM
Diode Dynamics
Exceptionally easy, most likely the easiest modification you'll ever do to your G37
If you have any questions about the installation, feel free to give us a call: (314) 205-3033
Thanks!
Nick C.
Old Sep 25, 2014 | 02:41 PM
Redfire32's Avatar
Redfire32
Ginger ninja
Thanks!
Nick C.
I think I'll just take your word for It and place an orders thanks
Old Sep 26, 2014 | 03:45 PM
Diode Dynamics
I'm Paul, the owner of Diode. I drive an 09 coupe, and I've installed LEDs on about a hundred different makes and models of vehicles, and Nissan/Infiniti is by far the easiest to change out. I love it.
Glove box takes a few minutes because you have to take out a few screws, but it's still very easy. No super-tight spots, hard-to-reach bulbs, etc. Should take you no more than 30 minutes to change everything out.
Old Sep 26, 2014 | 03:56 PM
JT2014's Avatar
JT2014
Although It was a little tricky to replace the map lights. I have big fingers & couldn't grasp & pull the stock bubs out easily. 1 I got & the other I used a plastic pointed object to pry it out.
Old Oct 6, 2014 | 09:09 PM
VeXeD's Avatar
VeXeD
Great informative post here, visited the DD website. Pics are worth a thousand words, nice side by side comparisons; stock vs. the various stages. IMO stage 2 is spot on (looking at pics), but after reading listed reviews stage 1 seems to be the choice....2 being to overwhelming inside........thoughts here? Greatly appreciated before I order....thanks Jay
Old Oct 7, 2014 | 02:34 PM
Diode Dynamics
We just got the new Hp3 194 bulb replacements in stock. They are the ideal bulb for practically every 194-location.
Feel free to give us a call if you need any opinions: (314) 205-3033
We are very well versed on the G35/G37
Nick C.
Old Oct 9, 2014 | 12:46 PM
ANMVQ's Avatar
ANMVQ
I absolutely love the DD stuff, I have been using their lights for the last 4 years !!
Old Oct 24, 2014 | 02:54 PM
BaapsG37's Avatar
BaapsG37
Like OP, my first post and my first mod. Ordered DD kit for entire interior, license plate and city lights a few days ago and they just got delivered...Wont be able to install until Sunday, but after reading this thread, I am def looking forward to it!! Thanks OP and DD!
Old Oct 24, 2014 | 03:02 PM
  #29
BaapsG37's Avatar
BaapsG37
LED fogs?
By the way, are there any instructions on how to install the fogs...thinking about getting a kit from DD, but not sure that the XML2's will fit my G37 (2011 X Sedan). Anyone have experience or opinions on the XML2s vs. the XP80s?
Old Oct 24, 2014 | 07:38 PM
  #30
BaapsG37's Avatar
BaapsG37
so it took about 30 minutes or so, but I'm done! The interior kit is very nice, and the leds are so bright. Great upgrade!
Now if I can only find where the "city light" bulbs go...where the hell is the city light??
