Need 2010 G37 Side Mirror Wiring Info
Old Aug 2, 2014 | 05:33 PM
bobcatm's Avatar
bobcatm
My 2010 G37 passenger side mirror got torn off... the good news is the only broken parts were the 2 triangular plastic mounting pieces... about $17 each.
The bad news is the mirror wiring came clean out of the connector block inside the door.
The wire colors on the mirror "pigtail" side of the connector (D33) don't match the the corresponding wires on the other side of the connector.
I have the full manual which shows the pins/wires/colors on the "car" side of the D33 connector but can't find any info on the proper terminals for each wire on the mirror pigtail.
All the posts I've found say to carefully record the wire colors/connector terminal #'s when removing, however in my case the wires got ripped out (amazing they are intact).
D33 is a 12 pin connector. The wires on the mirror pigtail are 2 black (for heater), 1 blue, 1 blue/black/, 1 yel/blk, 1 red/wht, 1 blk/wht, 1 yel & 1 violet.
Does anyone have a diagram or know the terminal #'s by wire color?
Thanks
Note this mirror has heater & memory...
Old Aug 3, 2014 | 10:58 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Hello Bobcat and sorry about your mirror. I took some pics of the wire connector from my '08 mirror. There are no differences between model years as far as I know. I replaced my mirrors with the power fold ones from the 'vert. Hope this helps!
Attachment 106223
Old Aug 3, 2014 | 11:01 AM
ILM-NC G37S
Attachment 106224
Apologies mods, for some reason my iOS won't let me upload more than one pic at a time!
Old Aug 3, 2014 | 11:07 AM
ILM-NC G37S
Final pic. Let me know if these help or if you need more.
Attachment 106225
Old Aug 3, 2014 | 11:37 AM
bobcatm's Avatar
bobcatm
ILM - Excellent - & Thanks a million.
The wires are the same colors - connector is slightly different. Saves me from tearing up driver's side to compare. I felt lucky that I didn't break any door panel clips, etc when removing the Pass side.
Old Aug 3, 2014 | 12:25 PM
ILM-NC G37S
As far as I know the connectors are the same. At least they are between my '08 and the '10 vert. Only difference is the extra wires for the power fold. Everything lined up perfectly. Door panels are very easy to disassemble- thankfully.
I'm glad I could help. If you need anything else let me know.
Old Dec 18, 2021 | 06:06 PM
nysha's Avatar
nysha
Same issue. Years later
Attachment 106225
anyway possible you would still have these pics? I think they’re too old on this post to pull up
GXXXVII
General Tech Questions
Dec 11, 2021 08:58 AM
Thedbarz
33
Feb 9, 2016 12:05 AM
maybeg37
Sep 8, 2015 02:33 PM
pcwd
Aug 12, 2015 06:54 PM
asato3
Aug 7, 2015 08:45 AM
