HID fog light issue
Old Jul 17, 2014 | 10:37 AM
wheres_jared's Avatar
wheres_jared
HID fog light issue
Hi everyone, I'm new to this site so I don't know if this will post in the right spot. But anyways, I have a 2010 G37s sedan and I installed new Xentec 8000k HID's in the headlight and 3000k in the fog light. They worked for about two months (some flickering here and there) but now, i was driving one night and one driver headlight turned on and both fogs were on. I switched them on and off a couple times and now the headlights are not turning on at all. The fuse is blown so I replaced it and as soon as I turned the lights on, the new fuse blew instantly. Please help!!
Old Jul 17, 2014 | 10:53 AM
ANMVQ's Avatar
ANMVQ
Did you wire these yourself? It sounds like you have a power wire touching a ground wire or grounding out. Recheck all you connections and make sure they are in good shape. I either solder all my stuff or use quick connects and wire sleeving
Old Jul 17, 2014 | 11:07 AM
pledes23's Avatar
pledes23
Did you just install the bulbs on the headlights or did you replace the entire HID system?
Old Jul 17, 2014 | 11:48 AM
wheres_jared
I wired them up myself. I cut the wires to the stock ballast and used connector sleeves and electrical tape for both. Could it be that there is two separate 15A fuses for each headlight and there is one 15A fuse for the fogs?
Old Jul 18, 2014 | 10:10 AM
ANMVQ's Avatar
ANMVQ
I know the fogs and the parking lights have their own fuse in the passenger side fender fuse box. :/ I blew mine install my custom LED's. I actually wired mine from there too
redlinernyc
Feb 29, 2016 11:06 PM
ZachThomas
Sep 3, 2015 01:40 PM
TVPostSound
General Tech Questions
Sep 2, 2015 04:09 PM
dlc1988
Sep 2, 2015 09:40 AM
R1 Dan G37
Aug 27, 2015 09:55 AM
