Passager side water leak
Hey guy latey I been getting this water leak under the glove box on the right side of it. Only leaks if it's raining hard for a long time. Light rain shower and car washes are fine no leaks. Has anyone came across this problem
Do you have an aftermarket amp/sub installed on your car?
if so, in order to run the power wire to the trunk a hole needs to be cut in the rubber grommet to feed the wire through the engine bay. I've read of this happening to people becuase of the hole that was cut into the grommet. If so, you need to seal the hole with some sort of silicone or sealant so this problem doesnt occur.
