DRL LED aftermarket install <$15
Old May 10, 2014 | 04:31 PM
Paratrooper's Avatar
Paratrooper
Hey whats up, I decided I would go for a custom look for DRLs. I went with 4 eagle eye 3W units, and they came from Ebay at $15. I also installed these directly to ACC surce (hot in run), so they come on automatically with the car. Anyways, here ya go!
Ran a single wire through this driver side grommet, down to the interior fuse block and tapped into an acc source.
The entire install was spent laying on cardboard, wiring everything up. I grounded all wires to existing ground spots. A couple zip ties and its clean.
I like this setup because I can add an additional eagle eye 3W light if I wanted 3 bulbs.
Old May 10, 2014 | 04:35 PM
MalbecG37S's Avatar
MalbecG37S
Kudos for the clean install. Looks nice.
My .02 cents...it may be the pic or the lighting, etc.....but they look a little dim? Maybe adding a 3rd would not be a bad idea...
Old May 10, 2014 | 05:21 PM
Nice, clean & understated, good job!
Might want to add another two on each side going up the curve, just to flow with the under-grill a bit. Either way, it's a win IMO.
Old May 10, 2014 | 05:53 PM
MalbecG37S's Avatar
MalbecG37S
And...ummm...isn't $15 < $50?
Old May 10, 2014 | 07:58 PM
Paratrooper
Ah damn. I put the wrong symbol. Should be <$50. Hey mods, can you edit my thread title to say less than $50??? I spent $15 on a set of 4 lights, and a few bucks on some wire and connectors.
I may add additional ones not sure yet. They are pretty bright though, the second pic is with them off. Will update later with a night pic.
Old May 11, 2014 | 10:47 AM
Paratrooper
Night shots
Old May 11, 2014 | 10:57 AM
Looks plenty bright from those pics, pretty impressive. Oh and I changed the title again switching the > for <, lol.
Old May 11, 2014 | 11:44 AM
monytx's Avatar
monytx
Nice install man. Looks like a clean job.
Old May 11, 2014 | 08:28 PM
VeXeD's Avatar
VeXeD
**** bro, nice finish...hooters
Gotta eBay link...
Old May 11, 2014 | 08:39 PM
VeXeD's Avatar
VeXeD
Will look into this, thus being no fog light rewire with running lights...
Old May 12, 2014 | 07:47 AM
Paratrooper
Quick search from my work computer keeps bringing up foreign lisitngs but you get the idea, heres a Lot of 10... same product though. Try to find the ones from a U.S. company, they shipped really fast.
10X 3W LED Eagle Eye White Light Daytime Running DRL Tail Backup leds Car Motor | eBay
Old May 12, 2014 | 08:55 AM
MalbecG37S's Avatar
MalbecG37S
Originally Posted by Paratrooper
Yes, they seem bright enough
Nice job!
Old May 12, 2014 | 09:42 AM
connoisseurr's Avatar
connoisseurr
I'm surprised a company hasn't replicated OEM DRL fog grille inserts like one did for the illuminated sills.
Sure seems like an easy job to do.
Old May 12, 2014 | 10:54 AM
TenshiroG37's Avatar
TenshiroG37
I can vouched for these. I used them before on my other car, they're pretty even with direct sunlight and very bright at night. I use a combo of 3 LED each side, but 4 each side would look even better.
Nice job!
Old May 12, 2014 | 09:00 PM
hddriving's Avatar
hddriving
simple and clean, i like it
