Light flickers
Old May 1, 2014 | 11:41 AM
RPG11's Avatar
RPG11
Light flickers
So as the title says the backlight of my RPMs flickers and goes in and out I dont know what it could be from and the dealer charges me $150 just to see me. Any help will be appreciated.
Old May 1, 2014 | 09:48 PM
monytx's Avatar
monytx
Could just be bad wiring. You could have a loose connection in there. I doubt it would be fuse related.
Old May 2, 2014 | 09:19 AM
RPG11's Avatar
RPG11
Do you have any Idea where those wire would be? I think it happened after installing my cai.
Old May 2, 2014 | 11:59 AM
monytx's Avatar
monytx
I'm assuming it's right under the dash, or behind it.
Old May 3, 2014 | 02:46 PM
RPG11's Avatar
RPG11
I was noticing that it would flicker every time i hit a pothole. Ok Ill check under the dash tomorrow and let you guy know if it works.
Old May 8, 2014 | 08:32 PM
RPG11's Avatar
RPG11
Nope nothing seems to work
Old May 13, 2014 | 06:45 PM
Dk43086's Avatar
Dk43086
Same on my 08. Weird thing is that it just flickers when it wants... I'm going to have to strip the cluster down sometime this month....
Old Sep 2, 2014 | 09:10 PM
duffster's Avatar
duffster
Did this dash light issue get fixed. My 09 is having the same issue. The back lighting on the temp gauge is off and on randomly, and now the whole cluster(including the center info in "red") goes out and then comes on a day later.
Also any info on the dash disassembly would be helpful.
Old Sep 10, 2014 | 01:41 PM
Detail's Avatar
Detail
I'm stuck in the same boat. $800ish to replace.
Gefartenblatz
Nov 10, 2015 11:45 AM
MEH2013G37
Sep 24, 2015 08:37 AM
pcwd
Sep 15, 2015 10:06 PM
CasperG37
Sep 14, 2015 07:46 PM
B Feelgood
Sep 13, 2015 05:56 PM
