fog light wont turn on
Old Mar 22, 2014 | 01:14 AM
GORILLA GAINS's Avatar
GORILLA GAINS
Ok so last night i was putting in the led fog lights i bought from diode dynamics and i discovered the light wont go throught the hole in the head light. So i was going to put the stock one back on and now that fog light on that side does not work.......help?
Old Mar 22, 2014 | 03:38 PM
Carfanatic's Avatar
Carfanatic
Trust me i had the same conclusion, what a fail on both of our parts...
as for the bulb maybe you touched it with you finger and it fused .... i'm sure you didn't do anything to blow the fuse ... check the fuse box for the fogs maybe it blew because the LED SMD you bought took to much power to turn on ...
Let me know if your fuse was blown
Old Mar 24, 2014 | 07:46 AM
GORILLA GAINS
i cant find the headlight integrated fog light fuse. i found some next to the battery but that was it. and is LEDs not an option if this happens alot. what a pita!
Old Mar 24, 2014 | 10:07 AM
GORILLA GAINS
just bought some 12-SMD Side-Shine H1 LED Bulbs For Fog Lights from ijdmtoy. they seem slim enough to fit through the hole without cutting. can anybody confirm or deny.
Old Mar 24, 2014 | 08:50 PM
Carfanatic's Avatar
Carfanatic
You really are into the LED seen, well i took out my entire headlight so i had a really good look and in my opinion there is no way you can get led's into the fixture the clearance is just not there.
Just buy from china the blue H1 bulbs and problem solved i ordered for me it takes 2 weeks.
Btw did you get you original fogs working again ?
Old Mar 25, 2014 | 08:36 AM
GORILLA GAINS
no, dont know where the fuse is. and i havent had time yet.
tomro99
Nov 17, 2015 02:08 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
pauliewalnutzz
Sep 8, 2015 11:41 AM
dlc1988
Sep 2, 2015 09:40 AM
