My Modded GT-R Push Start Button...
Old Feb 15, 2014 | 09:51 PM
Dr.Pat's Avatar
Dr.Pat
I ordered it from Amazon and had it shipped directly to OnlyNismo to change the LED colors for me. The Start/Stop lights up white...the rest lights up in a blue that matches the blue in the gauges and center console. Great work and super fast shipping.
The install took less than 5 minutes...
Get a small flat head screw driver...gently slide the tip between the chrome trim and the dash and twist. There are tabs that hold the button in place (which is why its harder to try to force it out by pushing from the back)...this will release them easily. Pull the button out as much as u can so that there is tension in the wire. Use the tip of the screw driver to push in the tab that connects the wire to the button. Since there is tension in the wire, the connector simply pops out. Take the new button and slide it into the hole. Hold the connector with a needle nose plier. Push the button in until you hear a click. All done.
1891459_550182004755_1552695696_o_zpsc60ce9f2.jpg?t=1392518868
1796784_550182034695_4207637_o_zps3c79fa1d.jpg?t=1392518911
Old Feb 15, 2014 | 10:45 PM
ZOSTER33's Avatar
ZOSTER33
Looks Good!
Old Feb 17, 2014 | 12:20 AM
10Gee37exeS's Avatar
10Gee37exeS
Definitely looks good. What year G did you install the button? I bought an '08 G button which should be the same as the GT-R button, but with the white, not red, button. But when I swap it into my 2010 G, the "ENGINE" letters does not light up. Ugh! I posted a wall of text in the G Sedan section about this...I'm wondering if I got a bad button...
Old Feb 17, 2014 | 08:26 AM
Dr.Pat's Avatar
Dr.Pat
I have a 2012 coupe...not sure why it didn't work...I think they are all compatible.
drewfinity
Sep 24, 2015 11:01 AM
Simran Mann
Sep 11, 2015 04:42 PM
Mattlorentzoe
Sep 4, 2015 10:41 AM
ZachThomas
Sep 3, 2015 01:40 PM
