Need Headlight/Fog HID Kit help..today!
Modding a car ain’t easy!
Need to buy new blubs/kit today so I can have it shipped for Monday delivery.
Act 1: Bought some cheap 6K bulbs from amazon.com. Mistake number one. They worked for a day. Then sometimes one wouldn’t come on, but if I turned them off and on they would. Ok Garbage. Should have known better.
Act 2: I bought Phillips Ultinon 6K from ebay. More appropriately priced, maybe $75-$100 (I can’t remember). Have them installed with HID Fogs (more on that below). They look great, but as I’m driving home I realize that the passenger side bulb is going pink. Then in clears up….then it goes pink again. After a few days its solid pink. Bad blub! SO I get the seller to send me another one. He does, I try to replace it as per the advice here. Ended up dropping it somewhere in the headlight housing? Or in the bumper? I was doing the jack up the car and reach your hand in the wheel well liner. GHETTO. End result (so long of a story) but I have a stock bulb in the driver side and one 6K in the passenger side…which is a bit pink ish but I don’t think broken? Its been so long now that I don’t even remember if the 6K phillps bulb is the bad one or if I was just disappointed in the 6K color produced by Phillips.
Question 1: Shouldn’t a 6K bulk produce an icy blue color….or atleast be on its way there? I hesitant to put 8K in there because I don’t want it to be BLUE = Silly. Any recommendations for an ICE blue color in D2S? Diode Dynamics sells CN Light (Chinese company).
Act 3: I had an HID Fog kit installed by my dealer at the same time as Act 2. 3K color temp, upgraded ballasts, but no relay to the battery. Regret decision? If I need it, why isn’t it mandatory? At any rate, it worked fine initially, like every, crumbled fast. I started noticing sometimes the driver side didn’t turn on. If I turned the fogs off and on again it would turn on. This bulb also seemed to be too green when warmed up. That’s a problem with 3K fogs in the first place. They don’t look like Lexus IS300 yellow or Infiniti QX4 yellow…they start GREEN…then warm up (slowly) to a pretty yellow color, but still hints of green. I digress. Diode dynamics sent me another bulb. Before I got a chance to put it in, the passenger side sometimes doesn’t turn on. Same issue, turn it off then on…it works. NOW, neither go on but the light in my guage cluster works. I doubt it’s the fuse. Could both bulbs have blown? Sucks.
Question 2: I’ll order a new fog kit, with maybe 4300K bulbs. I kind of like the look that stock has where the fogs and HID headlights don’t match. Maybe I’m crazing for doing this in the first place.
Maybe 6-8K headlights D2S and 4300K fogs? Any advice? Pics?
Thanks for sticking with this.
Mike S.
Mike S.
One answer! The Retrofit Source Inc !
also I wouldn't do 6000-8000k... You lose a lot of light output (lumens) I personally as well as many other people would go for 5000k Osram CBIs that have more lumens than the OEM 4300k bulbs ( and OEM bulbs usually have the most lumens ) and then if you would want even more light output I would recommend getting the fresnel lenses swapped out for clear lenses (TSX-R for the Coupe and STI-R for Sedan) this way your light output would be even better ! and get matching 5000k , it looks so nice and clean and the light output is amazing just simply PURE WHITE no tinge of blue !
I researched Retrofit as I sent that massive post. I think I'll get the 5000K for sure. A bit whiter and MORE light. Seems like a no brainer. Hopefully they don't blow out or fail!
I might go for the 4300 H11 HID Fogs since I want more output and I won't mind if they area a little more yellow. Sometimes I don't like them to match..dunno if that sounds weird. Guess I'm used to HID Headlights and Halogen fogs.
We used to include a relay harness with every kit, but we had many customers who already have relays from an old kit, or know that their vehicle does not require it, and too many people called in and asked to remove it from the kit before their order shipped. We thought that was the best thing to do, but unfortunately, some customers still choose not to get the relay, and then when it doesn't work properly, it's our fault. Point taken, you're right. Even though a relay's only required for operation about 5% of the time, in March, we're just going to build the price of the relay in with the kit at $150.
This new HID kit will exceed the quality of anything else on the market, including TRS, and will be launched in March.
OP, just shoot us a PM with your info and we can send you a relay free of charge. That will solve the problem for you.
Thanks,
Paul
hes' right you need a relay harness
you can get them on ebay for like $10-20
I never use a hid kit without one I had 2 on my last car but it also was a 11 year old car.
running 35 w through your wires is fine but the start up of the ballasts consumes more power so a relay is smart since it puts a fuse between the ballast and the oem wires as well as provide constant power from your battery.
optikol
Jan 28, 2016 07:31 PM
RexHavoc
Oct 2, 2015 11:47 AM
