Headlight relearn?
Old Jan 4, 2014 | 08:17 PM
Rikter's Avatar
Rikter
Headlight relearn?
Here is an interesting issue I haven't been able to find covered yet.
2008 g37s. Got to work and as I was pulling in my TPMS light came on. On my lunch break I hooked up my compressor to my cigarette lighter and checked all tire pressures. One was out of sync with the others so I filled it back up and will address that issue shortly. When my shift was over I went to start my car and it failed on the first attempt with the usual symptom of a low charge. Crank no fire and sluggish sounding. Pressing the button again it sluggishly tried to fire up and succeeded and haven't had any problems since. In hindsight I should have turned the car on when running the compressor.
My issue:I usually keep my lights set on automatic but now on automatic it instantly turns the lights on even in the brightness of day. I can manually turn them on or off.
Is there some sort of relearn process or maybe disconnect the battery to reset the ecu?
Thoughts?
Old Jan 5, 2014 | 01:08 PM
Polar_g37s's Avatar
Polar_g37s
There's a sensitivity setting for the lights, maybe that changed. Give it a shot.
Old Jan 5, 2014 | 02:02 PM
Rikter's Avatar
Rikter
Thanks I'll look into that.
2K1 6T8
Oct 6, 2015 07:40 PM
takeapieandrun
18
Sep 27, 2015 12:36 AM
Allboutcali
Sep 26, 2015 03:43 PM
pauliewalnutzz
Sep 8, 2015 11:41 AM
