Those with hood vents
Old Oct 1, 2013 | 02:07 AM
G37Sam's Avatar
G37Sam
Do you daily drive your car? How do you deal with rain and car washs?
My engine bay heats up quickly especially when idling so I need to vent.
Old Oct 3, 2013 | 01:59 PM
ANMVQ's Avatar
ANMVQ
Hey Sam I did dd drive mine rain snow what not, but car washed
Hope you mean by hand,
Old Oct 4, 2013 | 04:27 AM
G37Sam's Avatar
G37Sam
Yeah by hand of course. I'm just worried of water getting into the engine bay.
Old Oct 4, 2013 | 11:04 AM
ANMVQ's Avatar
ANMVQ
Better be by hand LOL, yea the water in the engine bay sux but you need it especially if FI my hood is a " one off" so I don't have a lot of big vents I try to spay away from the vent holes an usually pop the hood after and wipe down what I can .
Old Oct 5, 2013 | 06:03 AM
Presto's Avatar
Presto
Why not some kind of setup where you can close the vents before a car wash. I'm sure carbon signal can design it
Old Oct 5, 2013 | 06:09 AM
G37Sam's Avatar
G37Sam
I was actually thinking of a design where you would have a lever inside the car that can open and close the vents just like an exhaust valve.
Old Oct 5, 2013 | 10:29 AM
soolman32's Avatar
soolman32
I like idea Sam. I've been debating going with a vented hood (mostly for looks) but the idea of water getting in the bay has been a turn off. If you came up with something carbon signal could mass produce, I'd be in.
Old Oct 5, 2013 | 11:21 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Would be better if you could attach a solenoid and some wiring to your dash. Varex has a muffler that opens and closes like that, something inspired like that would work.
Old Oct 5, 2013 | 03:13 PM
Tcruarceri's Avatar
Tcruarceri
Boss mustangs had a functional flap that was activated via a **** inside, probably wouldn't be hard to wire up, but most things are waterproof under your hood anyway. Another option might be fitting a prefilter to the scoop/vent, companies sell relatively inexpensive prefilter material that is hydrophobic.
Old Oct 5, 2013 | 05:24 PM
G37Sam's Avatar
G37Sam
Hmmm.. I like the idea of a "hydro-phobic" filter. As you said everything is mostly covered. I'm just concerned with sensors and a few wires here and there in my engine bay.
Old Oct 5, 2013 | 08:03 PM
Tcruarceri's Avatar
Tcruarceri
It's trickle down military tech iirc. I run one on my 4x4 because I don't trust performance filters in the environment. Found it on eBay Rediculously cheap from a brand that had been tested.
tomro99
Nov 17, 2015 02:08 AM
Striderx88
Oct 10, 2015 10:42 PM
ZachThomas
Sep 13, 2015 06:56 PM
