Help Are there any DIY for tsx lens?
Old Aug 10, 2013 | 03:41 PM
08G37SBLUE's Avatar
08G37SBLUE
I can't find any DIY Instructions on changing out the projector lens to the TSX lens.
Is it a easy change out or very easy to mess up the whole headlight?
Old Aug 14, 2013 | 07:01 PM
viet2100's Avatar
viet2100
Open the headlights and take apart the projector. Can't really mess it up.
Old Aug 14, 2013 | 08:07 PM
Here's a thread on the STiR lens (same as the TSX but for the larger sedan projector). About the only real issue is the phillips screws holding it in, they're tighter than hell so you need to really put a lot of downward force when twisting. If you don't know this going in it's easy to strip it out. Also the metal ring spacer is used if you want a bit sharper cutoff than the oem cardboard washer and a bit more blue around the light edge. I just used double cardboard spacers since the ring spacer didn't sem to hold the lens as well. I think I was just being paranoid, but the double cardboard worked fine for me
Here's the thread, and BTW, about the best $50 you can spend
Anyone do the STi-R lens swap? - G35Driver
beng37s
Dec 8, 2019 01:21 PM
timc00k
Feb 15, 2017 09:15 AM
takeapieandrun
18
Sep 27, 2015 12:36 AM
Allboutcali
Sep 26, 2015 03:43 PM
