2009 G-37 RH door lower speaker grill
Old Feb 24, 2013 | 07:46 AM
corkyboy's Avatar
corkyboy
Hi Group:
I accidently put a hole in my door's lower RH speaker grill carrying a leaf blower in the front foot well of my G-37 Coupe. Dumb! Dumb! Dumb! Anyway the only way to replace it is by pulling back the door panel to remove the grill's bolts.
The <nobr>service manual</nobr> tells you to pop out the door entry light, the one upper inside door handle bolt, the two bolts attaching the large pull handle, and then pry off the plastic clips around the panel. I was wondering if I would be able to just do the bottom section enough to take out the speaker grill bolts. BTW I've ordered some of those plastic pry tools, so I won't damage any trim stuff. The dealer is charging $36.00 for the actual part, so be careful of what and who you're carrying in your front seat. Thanks, Corky
G37xhibeet
Nov 15, 2016 09:29 AM
aktif8
May 23, 2016 11:56 AM
Simran Mann
Sep 11, 2015 04:42 PM
Andyg90
Sep 2, 2015 06:10 PM
