where to buy third or is it fourth light for rear diffuser?
Are you referring to what the Z has in the rear? I think there was a sedan on these forums that bought one from a dealership modded it to fit.
Is this it?
https://www.myg37.com/forums/showthread.php?p=3477881
Is this it?
Tap into tail lights if you want to always be on OR tap into fogs if you want to come on with fogs OR put a toggle switch to manually power it on when you feel.
PS: The correct way is to run the wire from the light ALL THE WAY TO THE FUSE BOX however a ghetto approach would be to directly Tee off the tail light harness.
Topher9425
Dec 1, 2015 03:00 PM
