Squeaky Window Seal
Old Dec 10, 2012 | 08:00 PM
Brian Thompson's Avatar
Brian Thompson
Squeaky Window Seal
My driver's side window seal is squeaking every time I open or close the window, which includes closing the door (because the window goes up slightly on the coupe when you close the door). I searched for a fix, but all I have come across is recommendations for silicone spray, which I have already tried.
I probably will end up replacing the window seal, but I wanted to see if anyone had any recommendations on what else to try to stop the squeaking.
-Brian
Old Dec 10, 2012 | 08:25 PM
ECain18's Avatar
ECain18
Id like to know as well. Mine is pretty bad
Old Dec 10, 2012 | 10:11 PM
TheGanglyGoon's Avatar
TheGanglyGoon
Mine is unbelievably loud
Old Dec 10, 2012 | 10:34 PM
jon23's Avatar
jon23
I had the same issue, and got it fixed. I cleaned the window seals thoroughly with a towel using soapy water followed by degreaser. Afterward, I used silicone spray to lube it back up and problem has been gone for months now!
Hope that helps.
Old Dec 10, 2012 | 11:26 PM
TheGanglyGoon
Hope that helps.
You are the man Jon, Thank you!
Old Dec 14, 2012 | 03:55 PM
jon23's Avatar
jon23
No problem at all, glad to be of help!
Old Dec 14, 2012 | 06:38 PM
DeamonG37s's Avatar
DeamonG37s
cleaning them thouroughly helped me
Old Dec 15, 2012 | 03:55 PM
R.L. ina G37's Avatar
R.L. ina G37
Same deal with me, I'm going to try what jon23 suggested. Hope others had success with theirs.
Old Dec 25, 2012 | 09:46 PM
1NEETO's Avatar
1NEETO
I got the same problem but what annoys me the most the wind noise that comes from the drivers side window. I read somewhere I can adjust the angle of the window but I have no clue how.
Old Dec 26, 2012 | 10:08 AM
cruzmisl's Avatar
cruzmisl
When you take the door panel off, there are screws that control the angle of the window.
Old Jan 11, 2013 | 06:32 PM
alanro's Avatar
alanro
my 09 coupe driver window also squeaked going up the final few inches.
dealer adjusted and lubed track under warranty, all good now, 6 months ago
Old Jan 23, 2013 | 01:27 AM
Rubber's Avatar
Rubber
Jon,
Thanks for the info. After 4 months my squeak is finally gone after a good cleaning. (Didn't lube it in any way)
Thank you!
Old May 20, 2014 | 05:28 PM
G Nepal's Avatar
G Nepal
^^ Rubber didn't need any lube.. LOL
Old May 21, 2014 | 08:47 PM
SatinBlackG37's Avatar
SatinBlackG37
Having the same issues with driver side window, can you post up which silcone spray you used? Also my driver side window wont automatically close with the button it goes up and comes down, its been programmed but still does it? I can close it manually though... any ideas?
Rybitron
Nov 18, 2015 03:11 PM
RexHavoc
Oct 2, 2015 11:47 AM
CiViCKiDD
Sep 24, 2015 10:47 AM
Wreckreation
Sep 21, 2015 06:27 PM
