DO the 2010 headlights have auto level?
I understand the 2008 & 2009's with tech package had headlights that would level and swivel when turning the steering wheel.
But in 2010 the headlights don't swivel left/right with the steering wheel. However do they still auto level?
Any issues you all have seen from lowering the car with the auto level if it does in fact still have auto level?
TIA
TIA
From the 2009 G37 Coupe/Sedan Owner's Manual:
"AFS will also adjust the headlight to a proper
axis automatically, depending on the number of
occupants in the vehicle, the load the vehicle is
carrying and the road conditions."
My 2007 has auto leveling headlights.
Lowering the car lowers the headlight level. The sensor is on the rear suspension so the car thinks it is butt heavy and pointed up which in turn causes the headlights to aim slightly lower.
The headlights can be corrected using CONSULT or by manually adjusting.
I never bothered to re-adjust mine after lowering but will do so the next time it is hooked up.
The FSM will tell you if the 2010 has headlight leveling.
I lowered my 09 G37S coupe on coils and the level of the headlights is definitely off, they seem to be pointing down and actually cutting down the bright area a lot and making it dangerous to drive at night at 60+ mph. Does the 09 have auto leveling or how would I go about and correct it?
I also have AFS on my '08 and when I lowered it on Eibachs, I did notice a difference on the headlight aiming. All you have to do is adjust them, you can find how to do that here:
https://www.myg37.com/forums/d-i-y-i...djustment.html
Upscale Speed
Oct 9, 2015 01:42 PM
