Headlights not working - Big Issues
Old Jun 27, 2012 | 07:26 PM
SpartanG37S's Avatar
SpartanG37S
All,
Three days ago, my driver side headlight stopped working. No big deal, figured it was the bulb, so I ordered bulbs.
Installed the bulb today, and no dice. All other lights work, except the headlight (hi or low beam).
I checked the fuses in the fuse box next to the battery, which is a royal pain in the **** to take out, but all is well there.
I pulled the passenger side headlight and tried it on the driver side, no dice.
When I went to plug the passenger side headlight back in its original place, now It's not working either. So now, I have not one, but two dead headlights.
Again, all other lights work. Turn signals and fogs, but no headlights hi or low beam.
I'm in a bit of a pickle, so any help would be greatly appreciate.
Old Jun 27, 2012 | 07:33 PM
GET_SOME's Avatar
GET_SOME
i would be looking at a problem with the ignitors or ballasts
Old Jun 27, 2012 | 07:37 PM
SpartanG37S
Tried switching the ballasts, no dice.
Old Jun 27, 2012 | 07:41 PM
gizmo134's Avatar
gizmo134
Did you check to see if theres power at the plug going into the ballast?
Old Jun 27, 2012 | 07:48 PM
SpartanG37S
I don't have my volt meter handy, but it looks like I'm going to have to get it from my trailer. I'll see if I'm getting power at the ballast.
Old Jun 27, 2012 | 08:52 PM
gizmo134's Avatar
gizmo134
if you can get to it, that would be your best bet. Do your cutoff's work when you hit the high beam switch?
Old Jun 27, 2012 | 08:59 PM
Is your car not still under warranty?
warpeacelove
Oct 28, 2015 02:59 AM
JakeG37
39
Oct 19, 2015 11:09 AM
maybeg37
Sep 8, 2015 02:33 PM
Ricio1991
Aug 23, 2015 10:44 AM
DennisG37
Aug 1, 2015 11:37 PM
