Changing auto shift knob?
Old Jun 16, 2012 | 01:56 AM
QC-G37S's Avatar
QC-G37S
Changing auto shift ****?
I purchased a M45 shift know for my G and wanted to know if anyone that had done this swap before had any inputs.
It looks straightforward, pull down on leather boot cover, pull clip and remove original. Reverse on the install..
Am I missing anything?
Old Jun 16, 2012 | 02:53 AM
DeepRumble's Avatar
DeepRumble
Nope, thats it.
Old Jun 16, 2012 | 07:14 PM
paleryeder's Avatar
paleryeder
I like those M45 *****, been looking for a deal on a clean used one.
Old Jun 16, 2012 | 09:16 PM
bat6wc's Avatar
bat6wc
since the shift **** is shorter you will need to cut new hash marks into the shifter shaft for the locking pin.
Old Jun 16, 2012 | 11:15 PM
QC-G37S's Avatar
QC-G37S
Damn..Not what I wanted to hear....
If that's the case, I won't be doing the mod
Old Jun 16, 2012 | 11:17 PM
QC-G37S's Avatar
QC-G37S
Based on the reply above, mine may be up for sale
Old Jun 16, 2012 | 11:25 PM
bat6wc's Avatar
bat6wc
Its actually easy. You just cut a new small line on each side. Hacksaw works best but dremel or even steak knife. Takes 5 min and does not change or affect anything.
Old Jun 17, 2012 | 11:30 AM
QC-G37S's Avatar
QC-G37S
It looks like I'd have to cut the lines for the clip. Compared to a lot of mods folks do it's a "drop in", to me it's not.
Going to have to sell it
Old Jun 17, 2012 | 12:50 PM
bat6wc's Avatar
bat6wc
i urge you not to give up on this. the M **** makes a huge improvement on the looks. its worth the 5 min, or marking where to cut and then cutting a small hash mark on each side.
Old Jun 17, 2012 | 02:59 PM
TVPostSound's Avatar
TVPostSound
That was my very first mod!!
Remove the clip.
Slide the **** fully onto the shaft.
Get a hacksaw blade only (No frame), the cutouts for the keeper on the **** are your guides. Make grooves in the shaft with the blade until they are deep enough to retain the clip.
Slide the clip back into the ****, push down until clip locks into the new grooves.
Old Jun 17, 2012 | 03:41 PM
Schulminator's Avatar
Schulminator
^x2...Super easy "10min mod".
I took off stock ****, slide on the M and I used a razor blade to mark the spots then dremel with cutting wheel to make the slots a bit deeper...put M **** back on with clip...presto you're done...one of the best mods for the auto G. Best of luck!!!
Old Jun 17, 2012 | 10:31 PM
QC-G37S's Avatar
QC-G37S
Remove the clip.
You guys have convinced me to try it out
Old Jun 18, 2012 | 03:00 AM
saparda's Avatar
saparda
make a video of this!!! as i am buying one soon!
Old Jun 18, 2012 | 01:32 PM
bat6wc's Avatar
bat6wc
you will kick yourself for doubting how easy this is
Old Jun 18, 2012 | 07:40 PM
paleryeder's Avatar
paleryeder
Well if you chicken out let me know, if it's the smooth one with the stiching on the sides.
OneSickBlackG
Jan 6, 2016 08:49 AM
z_spec
Sep 17, 2015 11:49 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
harlemcat45
Sep 9, 2015 09:35 AM
inspector94
Sep 8, 2015 12:57 PM
