Rear Window cleaning behind center brake light
Old Mar 24, 2012 | 01:14 PM
Question Rear Window cleaning behind center brake light
Basically, how do you do it?
I've got streaks on the glass that I want to clean, but it's behind the center brake light. How do you guys access this area when you clean the rear window?
Old Mar 24, 2012 | 01:24 PM
canucklehead's Avatar
canucklehead
^ +1. no idea, at least without dismantling the light area.
Old Mar 24, 2012 | 05:10 PM
g37guy01's Avatar
g37guy01
Wondered about that also. How do you change the light bulb? The thing has to come apart.
Old Mar 24, 2012 | 05:25 PM
Rad_Slinger's Avatar
Rad_Slinger
i woud imagine you have to take it out in order to clean the glass underneath it.
same thing for changing the lightbulb.
Old Mar 24, 2012 | 05:48 PM
juicybusa's Avatar
juicybusa
You can fit a microfiber cloth between the glass and brake light.
Old Mar 24, 2012 | 07:26 PM
THAT'S IT!!!
Apply a generous amount of glass cleaner to a microfiber cloth, and slide it back and forth by the corners, slipping it behind the light against the glass. Then do it again with a dry cloth. Those nasty, thick streaks (of whatever) are gone.
Great advice, juicybusa.
Old Aug 11, 2012 | 11:17 PM
TinsleyC's Avatar
TinsleyC
Awesome. My goal for tomorrow.
Old Aug 12, 2012 | 12:09 AM
00Max00's Avatar
00Max00
Why do you want to change it? I think it is LED which supposed to last the lifetime of the vehicle. Even with the regular bulb in my Maxima, it is still original after what, 12 years and close to 200K miles!
Old Aug 12, 2012 | 01:15 PM
ashecnc's Avatar
ashecnc
I see your post now, I didn't find this before I posted the same question. I finally cleaned mine, it looked bad. At least you had some decent responses, my post was mostly full of smarta** comments. Thanks for the help!!
Old Aug 12, 2012 | 04:12 PM
blackhawksfan81's Avatar
blackhawksfan81
Microfiber towel or a folded piece of newspaper sprayed with glass cleaner.
ModInJapan
Brakes/Suspension
179
Jan 20, 2017 07:05 PM
ModInJapan
Engine/Intake/Exhaust
117
Jan 7, 2017 01:59 PM
ModInJapan
Brakes/Suspension
84
Mar 21, 2016 05:25 PM
ModInJapan
Brakes/Suspension
86
Mar 16, 2016 07:08 PM
Skeletor06
Aug 2, 2015 12:54 AM
