Running Lights Project...
Old Jan 2, 2012 | 03:37 PM
xtremeroller's Avatar
xtremeroller
Try automotive panel glue. Bodyshops use it to glue panels on vehicles together.
Old Jan 5, 2012 | 02:11 AM
TVPostSound's Avatar
TVPostSound
Originally Posted by sled
thanks... I tried this on the back and it pealed off fairly easily. I'm concerned about it's longevity.
I'm thinking possibly epoxy and several very small wire ties.
Any more suggestions?
I haven't tied tape. Do you know of a marine grade that will withstand the weather?
Hopefully soon...
Yeah i hope so. Thanks.
3m 5200
Old Jan 5, 2012 | 11:10 AM
surfjax87's Avatar
surfjax87
This stuff is used to attach body mouldings and such, so it should be fine.
3M Super Strong Automotive Attachment Tape, double sided tape, foam tape, 3M mounting tape
Amazon.com: 3M Scotch Mount Molding Tape, 3614, 1/2 in x 15 ft: Automotive
Old Jan 6, 2012 | 07:46 AM
sled's Avatar
sled
Thanks for the suggestions.
What I'm finding is even though glues will state plastic, there are exclusions for certain ones like polypropylene, which is what the faux vent is made of.
Right now I'm looking at a polymer bonding kit which is designed specifically to bond polypropylene.
Also, I'm still considering mechanical fastening.
Old Mar 11, 2012 | 11:35 PM
NaumanXenon's Avatar
NaumanXenon
Any mounted pics?
Old Mar 12, 2012 | 06:21 AM
sled's Avatar
sled
Not yet. I received the polymer bonding kit several weeks ago and it's a bit warmer outside now so soon. Thanks...
Old Apr 14, 2012 | 07:23 PM
sled's Avatar
sled
Moving along.
I hope this doesn't turn out to be an exercise in futility...
I've bonded the led strips and applied a coat of plasti-dip to cover the led strip base. I used a cut-up straw/tape to protect the leds.
Old Apr 15, 2012 | 02:37 AM
Kuro's Avatar
Kuro
^^^ installed pic please
Old Apr 15, 2012 | 03:00 AM
DeepRumble's Avatar
DeepRumble
This could be promising. I'm def sub'd.
Old May 19, 2012 | 05:54 PM
Romeo0119's Avatar
Romeo0119
Oh damn I can't wait for the mounted pic, been thinking about doing this, how much for both the led strips, approx how long are they? Did you have to cut them ?
Old May 19, 2012 | 06:06 PM
sled's Avatar
sled
Yeah, I can't wait either. I know it's probably hard to believe, but I haven't had an opportunity to devote the time. It'll probably be late June before I finish it up.
The LED strip is really reasonable. Here's the URL for the LED strips:
Oznium.com
Old May 20, 2012 | 03:32 PM
DeepRumble's Avatar
DeepRumble
Did you order 6" strips and is the color Neutral of Cool white?
Old May 20, 2012 | 04:47 PM
sled's Avatar
sled
9.5" White
I don't see what you've listed.
Old May 20, 2012 | 06:23 PM
  #29
Romeo0119's Avatar
Romeo0119
You are hooking it up to the main headlight switch I'm assuming right since American g37 doesn't really have day running light
Old May 20, 2012 | 07:17 PM
  #30
TwoThree's Avatar
TwoThree
Also looking forward to seeing this mounted! Hoping for faster progress than late June however lol.
