V-Leds
Old Dec 21, 2011 | 03:16 PM
dmeng's Avatar
dmeng
V-Leds
Anyone have problems with this company? I purchased a set of D2S Premium 8K Bulbs.
V-HIDS PREMIUM XENON HEADLIGHT BULBS D2S 8000K BLUE
Luckily it was the 1st bulb I tried that was defective or I would have wasted 1 hour. Bulb turned on for 1 sec and then shut off, installed the other bulb on same side and it fired up with no problem??
Compared to some other bulbs I've tried on my past vehicles, these "Premium" bulbs came shipped in some pretty generic box and wrapping? maybe I just have bad luck too!!
Any feedback would be appreciated, I'm trying to decide to give them another chance and ship me another set or just ask for refund and buy more name brand expensive D2S bulbs??
Thanks!!
Old Dec 21, 2011 | 05:17 PM
jhenka's Avatar
jhenka
Thanks!!
Don't sweat it. Assuming your G is 2010+ you have a ballast in your passenger headlight (i believe) that is very temperamental. Alot of HIDs will either burn out or refuse to fire. I have a set that's guaranteed to work if your interested.
Old Dec 21, 2011 | 05:47 PM
dmeng's Avatar
dmeng
Thanks, I have a 2011 IPL.
What type of bulb do you recommend or do you have and whats the light output? Mine was the Drivers side that was "temperamental"
Do you know what is the cause of this? Sounds like I just need to get a refund if thats the case
Old Dec 21, 2011 | 06:17 PM
jhenka's Avatar
jhenka
Yea get a refund and try a different set. The culprit is the voltage that the lights run at. The temperamental ballast will give an initial surge of power that the stock (expensive)hid bulbs are not effected by. The new aftermaket (cheap) hids aren't used to that surge and the initial burn-in fries them.
I've swapped hids for 12 G's so far and at least 4 of them had this issue. Mine actually burnt one bulb out as well.
2 ways of going around this issue. Getting a set of HIDs that are able to tolerate a wider range of voltage or get a new set and let them burn in (15-20 mins) on the ballast that works normally. After the initial burn in, let that bulb cool down ~5 mins and you should be able to put that bulb into the temperamental side without any issues.
Old Dec 21, 2011 | 06:31 PM
dmeng's Avatar
dmeng
WoW, thank you for the quick detailed reply!!
Any particular brand (expensive) HID Bulb that you recommend that are 6k or 8k? (PIAA, Phillips, Sylvania)??
Old Dec 21, 2011 | 07:05 PM
jhenka's Avatar
jhenka
to be honest its not worth it nowadays to get an expensive kit when you can get bulbs anywhere from 10 - 60 dollars a set. Find a reputable website and buy a set of bulbs and try it out. Most expensive doesn't always mean highest quality.
If your dead set on quality (expensive) look up morimoto, or philips will probably be your best bet.
Old Dec 21, 2011 | 09:04 PM
dmeng's Avatar
dmeng
Maybe I should just get the set that you already know works for sure.
Do you mind posting the brand and light output here or PM me please.
Thanks again for responding and being so helpful
Old Dec 21, 2011 | 09:30 PM
jhenka's Avatar
jhenka
No problem at all! hope it helps
I have a partnership with a company that manufactures leds, hids, etc. There is no specific brand. the light output ranges from 2800-3400 lumens depending on the Color temp you want.
I'm currently testing out an hid kit for back up lights if you interested as well.
Old Dec 22, 2011 | 12:10 AM
dudegetalife's Avatar
dudegetalife
hid backup would be badass definatly interested.
FlyLikeAG37
Oct 17, 2013 11:38 AM
2008G-Man
16
Dec 6, 2012 11:17 PM
ncpalafox
62
Dec 29, 2011 02:44 PM
ShyAznB8oi
Oct 13, 2011 01:11 AM
