Help Fog light install Fail
I have a 2008 coupe and upgraded to a 2011 s bumper with fogs.
I got HID for the fogs which are h11. I was trying to find a way to tapping into something for a power source. I tapped into my fog lamps that are integrated to my headlight. The yellow and black wire in the pic. i tapped into it on the drivers and tested it and it worked turned on fine with my fog light switch. Tapped the second one and tested it and then poof my fogs go off and so do the hid. I tested the fogs and hid directly to the battery and they turned on so no burned bulbs. I think i blew a fuse or something because my fogs wont come on anymore. Please help
TAPPED INTO THESE WIRES
Is your stock foglamp still hooked up? If it is you may have overloaded the circuit and blew the fuse. Try disconnecting the stock foglamps and try again. IF that still doesn't work you may need to add a relay to your hid kit
Yup. Sounds like you drew too much current through the fuse and it popped. Do what others have said and check the fuse, otherwise a relay may be needed. Pcasey also listed the patch harness that he used to avoid splicing the OEM harness.
Do you know where the fuse is? I checked the ones by the battery and inside my car but cant find one that says headlight. I talked to pcasey and he said he used a pigtail part number ac 120 to hook up his fog but i dont know where to tap in the pigtail for a power source. His fogs where regular h11. Im doing hid h11.
I found it, now im looking for which fuse?
my stock fogs in my headlight Are still hooked up, i disconnected my hid fogs in the bottom because this happened. Now im back to the beginning.
after replacing the fuse try to disconnect your stock fogs before trying. you don't necessary need a pigtail harness for such install imo. as long as you tap it nice and neat it'll work the same. good luck!
you need to remove the surrounding panels around the battery. it's in there and it's a huge rectangle black box that you have to pull out.
well i still need a switch to turn em off and on right? so they will be on all the time if i do it directly to the battery?
superjoey
31
Mar 22, 2023 11:56 PM
sydnrusty
Nov 21, 2015 10:42 PM
bikerjosh
Aug 19, 2015 11:26 PM
