Debadging: lettering outline remaining?
Old Sep 19, 2011 | 04:07 AM
Doggy's Avatar
Doggy
Speaking from experience, DO NOT use 1. Gasoline or 2. Laquer thinner or any kind of thinner. Rubbing compound is enough
Old Sep 19, 2011 | 03:59 PM
daicon0's Avatar
daicon0
Like most people said, rubbing compound, polish then wax by hand, if it's still there, do it again, if still there after that give it an hour or two then do it again, if all that fails which it really shouldn't then you'll have to use a buffer but personally I recently took off the back emblem from my 08 coupe and I only had to do the process once. The ghosting appearance from the emblem was really visible too. Good luck this is definitely the easy part
Old Sep 22, 2011 | 12:21 AM
Sena's Avatar
Sena
polish and wax
Old Sep 22, 2011 | 09:44 AM
_ant_'s Avatar
_ant_
Originally Posted by POLLO
If you're not comfortable in doing it , don't do it at all, or at least don't try to push it if you aren't making progress. I did the same and ended up jacking up my trunk lid that I needed to get it repainted.
lolz pollo is useless
Originally Posted by Sena
polish and wax
that should do it
Old Sep 22, 2011 | 10:04 AM
Kevalteam's Avatar
Kevalteam
OP pics of the outline? Did it go away yet? Update us! GL!!!
Victory
17
Oct 27, 2022 03:45 PM
j50ny
Jul 21, 2017 10:46 AM
Depravity
Oct 16, 2015 01:37 PM
footballmania32
Sep 4, 2015 02:17 PM
