10K HID help
Old Aug 15, 2011 | 01:41 PM
MWhiteV36's Avatar
MWhiteV36
10K HID help
So installed 10k hids at a local shop and now when ever i have my lights on auto one of the 2 light are always off! they said i have to put the light manual(it works)but is there any solution to this because i have auto for a reason
Old Aug 15, 2011 | 02:36 PM
Doggy's Avatar
Doggy
Maybe the bulb sucks. Mine works fine
Old Aug 15, 2011 | 02:51 PM
1BadAssG's Avatar
1BadAssG
There's a bulb problem. It shouldn't matter if its auto or manually, they both out put the same power to turn the light on. Is take it back and make them fix it.
Goonz's Avatar
Goonz
what can you see with those 10k's? sheesh
Old Aug 15, 2011 | 04:20 PM
2008G-Man's Avatar
2008G-Man
Geesh ...10K
Old Aug 15, 2011 | 05:23 PM
irwins's Avatar
irwins
You're gonna attract the unwanted attention of so many cops...
Old Aug 15, 2011 | 05:45 PM
Doggy's Avatar
Doggy
Just change the bulb.
Old Aug 15, 2011 | 06:01 PM
1cleanG's Avatar
1cleanG
NextLevel Performance
Holy Blue....what brand LEDs?
Old Aug 15, 2011 | 06:14 PM
1NEETO's Avatar
1NEETO
Blue? 10k is more like purple.
Old Aug 15, 2011 | 06:21 PM
Doggy's Avatar
Doggy
10k can be blue or purple. Just like 6k can be white, blue, or purple.
Old Aug 15, 2011 | 06:38 PM
_ant_'s Avatar
_ant_
10k is rice but if you are intent on running it then you'll need another set. Sounds like a problem with the bulbs and cheaper bulbs usually have this problem.
Old Aug 16, 2011 | 12:36 AM
1NEETO's Avatar
1NEETO
If you buy 6000k HID's and they come out purple, return them because you got the wrong lights. 6000k should be blue-ish white. You're right that according to the color temperature chart, 10000k is sky blue. 7000 to 8500 should be purple-ish color. After 10000 the color gets cooler until fully cool which is black.
Old Aug 16, 2011 | 12:46 AM
Doggy's Avatar
Doggy
True, but not always. Some 6k have different hints. My friend has 6k turquoise, other friend has 6k white. Check this out 6k that's purple tint.
V-HIDS 35W SLIM BALLAST XENON HEADLIGHT KIT H1 6000K PURPLE TINT B/O
Old Aug 16, 2011 | 08:00 AM
2008G-Man's Avatar
2008G-Man
6500K is Daylight and should have a very slight hint of blue .... this is in a perfect world. As we all have noticed the color temp runs the gammit on manufacturers. In general terms, in the LED/Bulb world a 5K bulb will give you very close to white, 6K perhaps a hint of blue. El-cheapo's from Wal-Mart or Pep Boys ....6k probably has quite a bit of blue.
Old Aug 16, 2011 | 12:22 PM
Goonz's Avatar
Goonz
stick with 4300K, its the brightest bulb there and you will see more in the rain rather than 10k
