Question About Display Brightness
Old Jul 26, 2011 | 11:49 AM
fluxemag's Avatar
fluxemag
I have a 2010 non-nav coupe. The LCD display screen has two primary brightness settings, max bright and less bright (I can also adjust anywhere in between). For some reason the setting for night time when the headlights turn on is max bright, and the setting for day time is the lower brightness setting. This makes no sense and seems backwards. I need it to be max bright in the daylight otherwise I can't see it. And I need it to automatically dim at night so I can see outside. These are the default changes that happen if I don't touch anything, so I always have to hit the brightness button after I start the car to get the opposite setting. Is mine broken?
Old Jul 26, 2011 | 08:16 PM
bluecoupe's Avatar
bluecoupe
Press the "sun/moon" button the right side, this will change it from night to day mode.
Old Jul 26, 2011 | 11:44 PM
htownboy's Avatar
htownboy
If you read the owners manual you will find all sorts of cool stuff.
Basically; Just press the brightness button then turn the big **** between all the nav buttons to adjust for daylight\night time, then hit that brightness again to toggle and adjust again. It's easy, just try it.
Old Jul 27, 2011 | 11:32 AM
fluxemag's Avatar
fluxemag
I guess you missed the point. I know how to change it, I just don't think that I should have to every time I use the car, because the default is the opposite of what it should be.
Try reading the whole post next time before you start running your mouth!
"so I always have to hit the brightness button after I start the car to get the opposite setting."
Old Jul 27, 2011 | 01:12 PM
1BadAssG's Avatar
1BadAssG
woh you just earned the BAN badge my sir
Old Jul 27, 2011 | 04:18 PM
Viper62382's Avatar
Viper62382
Say goodbye to help from anyone else
Old Jul 28, 2011 | 12:09 AM
htownboy's Avatar
htownboy
Running my mouth... I wish you were here and told me that. Hey man, your the one who can't figure out how to easily work your freakin' brightness control. It changes when the lights go on or off and the control lets you toggle to the opposite or adjust each. What more could you want, mind control?
I've been here a very long time. Get off me
Old Jul 28, 2011 | 01:26 AM
voltic's Avatar
voltic
Everyone calm the F down.
Start the car with the headlights off. Set the display to the proper brightness.
Turn the headlights on and let it change by itself. Set the display to the proper (dimmer) brightness.
Now to more important things... where the hell is my easy button?
Old Jul 28, 2011 | 01:13 PM
GTLAW's Avatar
GTLAW
Oh wow, this too funny. Don't ask for help if your going to act like baby about it!
Raleclair
Oct 8, 2015 02:06 PM
beng37s
Intake and Exhaust
Sep 19, 2015 01:32 PM
ScrewstonNismo
Sep 15, 2015 10:34 AM
carid
Supporting Vendors
Sep 10, 2015 10:17 AM
joshferbs
Sep 9, 2015 08:53 PM
