passenger window "auto" feature
Old Jun 11, 2011 | 04:01 PM
pro-gadgeter's Avatar
pro-gadgeter
I noticed that my passenger window won't "auto" roll up. I tried doing it from driver side and passenger side. I have to hold on to the button till the window is completely up. Rest of the windows are fine. Has anyone else had this problem?
I need to get my transmission re-flashed as well so i guess i'lll have to take it in for this as well.
BTW, for 7at re-flash, do they keep the car or is it done right on the spot? and how do loaner cars work under warranty issues? Incase they need to keep the car, do i need to pay for it?
Thank you in advance.
Old Jun 11, 2011 | 04:21 PM
surfjax87's Avatar
surfjax87
Hold switch in up position for 15 seconds after it finishes going up. Do it for down as well if you need to.
Old Jun 11, 2011 | 04:38 PM
pro-gadgeter
i just tried it, and now, the window only closes like 2 cm and then i have to close it myself with hand another 2 cm... and repeat...
rks's Avatar
rks
Originally Posted by pro-gadgeter
...and how do loaner cars work under warranty issues? Incase they need to keep the car, do i need to pay for it?
It may vary by dealer but most provide free loaners if they need to keep the car. My dealer also has valet service where they will pick-up and drop off your car or even even leave you a loaner if needed.
Old Jun 11, 2011 | 08:43 PM
nbarone's Avatar
nbarone
I just had to reset my windows because i reset my ECU. There are instructions in the owners manual, but here's what you do.
1. Turn the car on, don't start it, just push the ignition so you get power.
2. roll the window down a little more than half way.
3. roll the window all the way up, and hold the window switch in the up position for about 3 seconds.
4. push the window switch and it should roll the window all the way down.
5. push the window swith up, and it should roll up all the way on it's own.
If this doesn't work, check the manual, the instructions are in there.
fuzzed
Aug 21, 2020 09:35 AM
SpeedBallDEVIL
Oct 2, 2015 11:20 PM
RexHavoc
Oct 2, 2015 11:47 AM
Awgd8
Sep 30, 2015 06:22 PM
Irishcurtis
Sep 30, 2015 11:39 AM
