Sedan Rear Seat Lighting - Bulb Questions
I've upgraded every bulb in my G37 Sedan except the ones in the ceiling above the rear seat. Does anyone know what size bulbs these are and how you remove the lens to change the bulb?
Is it the same size bulb as the normal map light? The housing seems much smaller and when I try to pry it, it feels like its going to snap off.
The bulbs inside the care are all t10 leds or 921 or w/e you wanna call it.
To pull of the white piece, you need to get a tiny flathead screw driver and stick it between the white and grey housing piece by the button. You'll need to push toward the white and it will just snap off its go to little clip type pieces on each side. Carefull not to push to hard you will leave a welt in the grey housing.
superjoey
31
Mar 22, 2023 11:56 PM
maybeg37
Sep 8, 2015 02:33 PM
