Rear Seat Removal
Old Mar 24, 2011 | 01:39 AM
roots4x's Avatar
roots4x
What are those round things on the floor, under where the seats would be??
Believe those have something to do with the fuel tank.
Old Mar 24, 2011 | 10:59 AM
mikelr's Avatar
mikelr
Yes, fuel pump access panels....
Old Apr 8, 2011 | 01:21 AM
TVPostSound's Avatar
TVPostSound
Yes the infamous dual fuel pumps!!
Old Apr 8, 2011 | 01:28 AM
Wezbian's Avatar
Wezbian
The rear seats are a pain to get up. The trick is not to actually sit on the seats (hope that was obvious) and crouch over the tranny hump and pull straight up. Be sure to pull the belts through the holes prior to sitting on the seat to clip it back in.
Old Dec 30, 2011 | 06:22 PM
usndocgreen's Avatar
usndocgreen
rear system
Has anyone out there replaced this area with a sound system. I searched but can find anything. would be interested in pics if so. THanks
Old Jun 2, 2012 | 01:16 AM
i3eezenotch's Avatar
i3eezenotch
Hey,
So was that indeed how you took off the rear seats? Just pulling up? I was in the back today and put one hand in the middle of each rear seat and pulled up relatively hard and felt like I would break something. I have an 09 coupe X. I know in the sedans there are some plastic pull clips. Can't find anything of the sort here.
I am trying to wire something from the center console to the trunk and thought this may be the easiest way. Unless I go from the center console down to the door sills and then to the trunk. Also, anyone know if there is a DIY for routing a wire from the center console to the trunk the best way? It would be nice to see some pictures.
Old Nov 30, 2012 | 04:23 PM
GSH1T's Avatar
GSH1T
so how much does the whole back seat weigh? want to know if it is worth taking out for performance purposes.
Old Nov 30, 2012 | 04:33 PM
Wezbian's Avatar
Wezbian
Unless you're going to the track and racing this car, it's not going to be worth it. You won't notice any performance difference taking the rear seat out. Probably best to trade in for a 370z in that case.
Old Dec 2, 2012 | 08:46 PM
GSH1T's Avatar
GSH1T
370s are too rice for me and aren't classy enough. So can anybody answer my question without putting their 2 cents in and tell me how much the back seats weigh?
Old Jan 1, 2014 | 04:17 PM
Darth Kinetic's Avatar
Darth Kinetic
I want to see and read something like this as well. Thinking of doing a custom fb sub in the drivers rear seat position
Old May 26, 2016 | 11:24 PM
basiccomplexity's Avatar
basiccomplexity
can someone post a diy guide on how to remove the rear seats?
Old May 27, 2016 | 03:30 AM
Not a DIY but was posted in post #6 of this thread... might help with all the other information given in this thread as well.
Rear Seat Removal ? - G35Driver
Old May 27, 2016 | 11:40 PM
350zspeed's Avatar
350zspeed
Originally Posted by Redline37
This is how it should look as the end result.
So much room for activities.
Old Dec 20, 2020 | 05:41 PM
  #29
JavierV's Avatar
JavierV
Attachment 172677
how did you remove the side panels? Trying to do that at the moment and cant seem to figure it out
superjoey
31
Mar 22, 2023 11:56 PM
Doug Crawford
Aug 8, 2015 02:08 AM
