H1 LED fog light bulbs
Old Mar 9, 2011 | 10:17 PM
yogregb's Avatar
yogregb
I got the ones from jdmtoy... I'll install soon. I ck'd them today and they are correct polarity. I'm going to try these as drls in the fog position and wire my custom fogs to the infiniti fog light switch....
Old Mar 10, 2011 | 09:46 PM
kmare's Avatar
kmare
I tried a while back; our H1 housings are very thin and the wide/square LED part could not fit through the bulb socket. You would need to try an H1 LED bulb that is flat (ie leds on either side of the circuit board)
Old Mar 10, 2011 | 09:54 PM
Clutchr6's Avatar
Clutchr6
Let us know how it turns out. PLease post pics
Old Mar 10, 2011 | 11:13 PM
yogregb's Avatar
yogregb
I'll check that out, if true, I don't see why I couldn't open up, the opening a little with a uni-bit....
Old Mar 15, 2011 | 12:30 AM
yogregb's Avatar
yogregb
^^^ this is true, I'm returning mine and ordering these flatter bulbs
H1 LED Bulbs Infiniti G37 Fog Lights Honda S2000 DRL Daytime Lights
Old Apr 12, 2011 | 02:23 AM
jmlenz's Avatar
jmlenz
How did these turn out? From what I understand using LEDs in the fog position are more for DRL purposes as the light projection is weak. How did these turn out?
Old Apr 12, 2011 | 11:25 PM
yogregb's Avatar
yogregb
Yeah, I'm not worried about light output on the fogs, I wanted a color match with my hids and parking/city LED, which are a 6k color.... My LED/drl light strips that I mounted down in the lower grills ended up being brighter then the fogs anyway!! Now everything matches.... I'll get around to posting some pics soon....
tomro99
Nov 17, 2015 02:08 AM
B Feelgood
Sep 13, 2015 05:56 PM
pauliewalnutzz
Sep 8, 2015 11:41 AM
