Help Xenon fog users: did you have to adjust after install?
Old Nov 22, 2010 | 09:56 PM
Mazaki's Avatar
Mazaki
Hey guys,
So I managed to finally get ONE of my fogs done in xenon, which was a total pain. Happy that I had gotten one done, I turn it on to test it...
And it's aimed ABOVE the low beam. Like, way above, high beam status. Did any of you have to re-aim or adjust your foglights after converting to xenon, or is there just something screwed up with my bulb/installation? I'm used a V-LEDs H1 kit, by the way. There's no flickering or anything, and the color is correct. It's just that the fog is aimed REALLY high and it's weirding me out. On my old BMW, when I converted the fogs to xenon, I didn't need to re-aim them.
Thanks,
M
Old Nov 22, 2010 | 10:23 PM
BooSa37's Avatar
BooSa37
This will help
https://www.myg37.com/forums/d-i-y-i...djustment.html
Old Nov 22, 2010 | 11:04 PM
Weiboy718's Avatar
Weiboy718
Originally Posted by Mazaki
Hey guys,
Thanks,
M
can you take some pic's of your bulb. i'm thinking that you installed it wrong and the bulb isn't flushed. you may want to double check it and don't adjust it as it does not need adjustments when only changing bulbs.
Old Nov 22, 2010 | 11:23 PM
Mazaki's Avatar
Mazaki
That's what I was thinking, but the clip seems to be holding it in place flush, and it isn't crooked in the housing.
Old Nov 22, 2010 | 11:25 PM
speedracer g37's Avatar
speedracer g37
i adjusted the fogs down almost 20 deg. after an even adjustment, i turned on the fogs and sat in another car about 100 feet away and checked the glare.
Old Nov 22, 2010 | 11:54 PM
Mazaki's Avatar
Mazaki
So yours had to be adjusted significantly too, huh?
I think what would help is if I do the other side tomorrow. If the other side is at the same height, then it's probably just the nature of my particular bulbs.
Old Nov 23, 2010 | 12:03 AM
Weiboy718's Avatar
Weiboy718
can you see if the bulb's metal filament bar is facing the top or bottom? it should be on the bottom.
Old Nov 23, 2010 | 12:12 AM
speedracer g37
i know mine are seated correctly.
Old Nov 23, 2010 | 12:29 AM
Mazaki's Avatar
Mazaki
It's on the bottom. Trust me, I'm not that dumb.
Same. I'm pretty sure mine's seated. The metal clip was able to hook into place and everything, and it visually looks flush.
Old Nov 23, 2010 | 02:38 PM
Tuckermaclain's Avatar
Tuckermaclain
My fogs were pretty easy to install on the 1020 sedan. I didn't change the aim at all on purpose. I use them like driving lights. I have noticed that people liotering in the left lane tend to notice them and move over more often. I like it.
superjoey
31
Mar 22, 2023 11:56 PM
sydnrusty
Nov 21, 2015 10:42 PM
sprix
SouthEast
Sep 7, 2015 11:16 AM
cparise
Aug 19, 2015 01:51 PM
