Headlight color code diagram, anyone got one?
Old Aug 3, 2010 | 08:37 PM
san~man's Avatar
san~man
Originally Posted by ucla bruin
The wire harness that powers the HID is connected to the ballast and it's got a steel-wool-like sleeve covering it. But there are 2 small wires (bluish green color) that connect to a plug right below the HID. I think those might be the high beam mechanical trigger. Maybe you can try splicing into those. Good luck!
Thanks. I guess I have to pull the intake filter out to check.
Old Aug 4, 2010 | 11:14 AM
ucla bruin's Avatar
ucla bruin
Np, the wires I'm talking about are very difficult to get to. It's inside the HID compartment. If you open the HID cover and look straight into it, it would be located near the bottom. I don't think you'd be able to reach the clip by hand. I use pliers to pull on the wires and simultaneously another tool to unclip it from the plug. It's like performing surgery.
__________________
Old Aug 10, 2010 | 03:17 AM
san~man's Avatar
san~man
Took it back to the stereo store I used to work for and my friend used a multi-meter to check the wiring. Works like a charm
If anyone's interested and buys one of the modules, I'll go and check the color codes.
Old Aug 10, 2010 | 11:30 AM
Noremac's Avatar
Noremac
I assume your HID's flash on when you do this? If so, do you have any concern about damaging them over the long term?
Old Aug 10, 2010 | 12:24 PM
san~man's Avatar
san~man
If by "flash" you mean illuminate the high beam of the bulb, then yes it does as I have to flick the headlight stalk twice to open the door.
I'm not really concerned about long term issues as I have the 7/100 warranty. Also, I had it installed over 2.5 years on the 3 without any problems
Raleclair
Oct 8, 2015 02:06 PM
Detailed Image
Lighting/Cleaning Products
Sep 11, 2015 08:33 AM
pauliewalnutzz
Sep 8, 2015 11:41 AM
allen738
Sep 6, 2015 09:36 PM
RexHavoc
Sep 6, 2015 01:03 AM
