08 coupe driver floor water leak help
Hey guys any one with a g37 coupe experience a slight water leak on the drivers side floor. everytime i wash my car or it rains and i drive threw it and it ends up making my floor slightly damp. no other areas of the car just drivers side. post up if you guys know anything thanks.
I work for Infiniti and have seen a few water leaks coming from the sunroof drain hose gromet that goes thru the firewall but I have only seen it on the passanger side. Chances are same on the drivers side. The fix was to remove the gromet and put sealer around the base of it and reinstall (pain in the a$$ with the dash still in). If you take off the drivers side kick panel and look under the dash towards the top of the firewall at the base of the A-pillar you might be able to see water marks where its getting in.
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
tite_tite
Aug 22, 2015 05:21 PM
pcwd
Aug 12, 2015 06:54 PM
