Where is the outside temp. sensor?
Old Jun 30, 2010 | 02:32 PM
SkyMG37x's Avatar
SkyMG37x
Originally Posted by Marc Collins
Half the cars put it near the radiator or somewhere at the front of the car (near the engine). The other half put it near the back bumper or higher up/under in the car. Which ones have engineers that understand the rather basic concept that the engine is a giant heat source?
All the cars that put them at the front have the same issue--it wildly overstates the temperature even just from the heat coming off the pavement or the heat coming from the engine if the car was run recently or from the engine itself if the car is running or more than one of these at the same time. I guess they like to put in guages that have no accuracy and are therefore minimally useful?!?!
Disagree. During normal driving airflow from the front of the radiator ensures the sensor reads ambient temp, not engine radiated temp. And since it's lower on the radiator support (and heat rises) it's further isolated from any engine heat. If you're in stop/go traffic you may argue that the temp at the sensor will increase, but keep in mind as soon as the coolant temp reaches fan threshold temps the cooling fan will come on ensuring proper airflow from the front of the rad. My previous car had it in the the front and closer to the pavement and it and this car are relatively accurate.
The purpose of the sensor is not to provide a "weather update" temp, but to provide the various systems in the car with the proper ambient temp whether it's heated by the pavement or other factors and used for calculations related to engine control, HVAC control, etc.
Old Jul 4, 2010 | 11:24 AM
TK5's Avatar
TK5
Outside Temperature Probe Location/Accuracy
Does anyone know where the outside temperature probe is located on my '08 G37s and how accurate it is?
Re: the accuracy, I am more concerned about the effects of sun and such on the reading because I am assuming a standard thermocouple is much more accurate than the 1 degree display.
Thanks,
Todd
Old Jul 5, 2010 | 01:56 PM
freesurfer's Avatar
freesurfer
Driving at speed could also affect the temperature readings, depending on its location.
Old Jul 6, 2010 | 06:13 AM
htownboy's Avatar
htownboy
Originally Posted by 15951
I've never had the outside temp be accurate at startup on any car that sits in the sun in hot weather. To be fair, it probably is pretty accurate, as it is getting heat from the asphalt, etc. Just drive for a few minutes and it will return to normal.
I concur... The radiant heat from sunlight, metal, road. cement etc. causes it to read high until you start driving and the ambient temp corrects the reading.
Old Oct 31, 2014 | 03:35 PM
JT2014's Avatar
JT2014
Have to resurrect this... My sensor is broken. I need to replace it. Anyone have a pic of it mounted? I know mine is broken off whatever bracket it sits on as it's dangling behind my grill & I have no idea where it's supposed to mount too.
Also a part number for replacement would help. And maybe even whatever part it mounts too.
Thanks
Old Jan 6, 2015 | 11:43 PM
smilinsteve's Avatar
smilinsteve
Noticed today temp showed 59 and it was 45 according to accuweather. This was during rush hour Denver traffic so slow speeds (low air flow) probably was at least part of the problem. It sounds like a common problem to have high readings, but is there something that can be done to correct it, or just have to live with gauge that doesn't work? My Explorer temp reading seems to be within a couple of degrees of weather report numbers, all the time.
Old Aug 23, 2015 | 02:11 PM
tbear's Avatar
tbear
From the FSM:
AMBIENT AIR TEMPERATURE
  • The unified meter and A/C amp. receives the ambient sensor signal from the ambient sensor.
  • The unified meter and A/C amp. calculates the ambient temperature according to the ambient sensor signal,
and transmits it to the combination meter.
• The indicated temperature does not increase if the vehicle speed is less than 20 km/h (12 MPH).
NOTE:
  • The ambient sensor input value that is displayed on “Data Monitor” of CONSULT-III is the value before the
    correction. It may not match the indicated temperature on the information display.
  • Ambient temperature may be indicated higher than an actual temperature, depending on heat in the engine,
a road surface temperature, and so on.
Old Aug 26, 2015 | 09:16 PM
mjunod's Avatar
mjunod
On my 2008 G37S coupe the temperature reading started show hotter than outside real temp even with highway driving. Started showing 10 degrees higher and wasn't until it read over 25 degrees higher when dealer replaced the part SENSOR ASSY-AMBIENT-27710-JL00A under warranty.
Old Sep 25, 2015 | 09:55 PM
abretz89's Avatar
abretz89
Just had this issue tonight while driving home. I was cruising thru town at 45mph or so with no traffic and the gauge was reading 102 when the outside temp was 79. This is at 9pm so no real heat off the road and a steady breeze. A/c was off with windows/sunroof open. Could having climate control off affect the reading?
Old Sep 22, 2017 | 06:11 AM
milosz's Avatar
milosz
From: Chicago home of the 2016 world-champion Cubs!
My outside temperature readings, once I have driven a few minutes at ~30 MPH, used to be pretty accurate, within a degree or so.
Yesterday I went to the dealership and had a bunch of stuff done - coolant flush/fill, brake fluid change, driveline fluids change and auto trans fluid change. When I left the dealership the indicated temperature was 10° higher than the actual ambient. I drove for 40 minutes and the indicated was still 10° above actual. Today, driving around, indicated was 10° above ambient.
So. WTF.
Changing fluids causes temperature inaccuracy? I don't see how.
I sent the service tech/writer an email asking him, "What is this?"
Is there a way to enter a correction or calibration into the system?
Odd. Just weird.
Old Sep 23, 2017 | 08:45 PM
Yellafella's Avatar
Yellafella
So. WTF.
Odd. Just weird.
Old Sep 23, 2017 | 09:03 PM
milosz's Avatar
milosz
AHA! Ambient (outside) temp sensor location
EXCELLENT PHOTOS!!!!! Very very good pictures there, many thanks.
I can see that it is real close to the radiator cap, so, yeah, maybe it got disturbed or soaked with coolant or who knows what might have happened.
I ordered a new sensor, or what I THINK is the Infiniti G37 ambient air temperature sensor Part# 27722-1VA0A. It was $19 incl. shipping to Chicago via Amazon.
It's not a big deal. But, I am curious abut what is going on. I'll replace the thing and see if the reading is more accurate.
It would nice if it was as accurate as it was when I got the car, which was really pretty accurate.
I'll take a look at the 27722-1VA0A when it comes, I am guessing it is a thermistor.
Old Sep 23, 2017 | 10:29 PM
Yellafella's Avatar
Yellafella
Lololololol
Old Sep 24, 2017 | 04:18 AM
  #29
milosz's Avatar
milosz
Very funny
Yeah, I looked, and, no, that's not where it is....
vamarris
Dec 9, 2018 11:10 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
2K1 6T8
Oct 6, 2015 07:40 PM
jgronline
Sep 21, 2015 08:44 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
