Help HID Fog help!
Old Apr 3, 2010 | 01:23 PM
XSman's Avatar
XSman
HID Fog help!
So I ordered a 35w 4500K slim ballast kit from DDM and I can't get it to work.
1. Removed neg battery connection.
2. Removed original fog lamp (driverside).
3. replaced with HID.
4. connect circular connectors
5. connected male H8 to harness connection (sedan uses H8)
6. connected female plug to ballast
7. reconnected battery.
Start car, turn on lights, headlights work but no light from fog. Replaced with original lamp and it works fine. WTF? HELP PLEASE.
Old Apr 3, 2010 | 01:40 PM
beerme986's Avatar
beerme986
Do both not work? did you check the fuse for the fog light? i would just double check connections
Old Apr 3, 2010 | 01:48 PM
Blackjack's Avatar
Blackjack
Pics may help us diagnose. My guess is something is connected correctly.
Old Apr 3, 2010 | 01:52 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
its probably b/c the fog lights are 55W NOT 35W
Old Apr 3, 2010 | 02:08 PM
Blackjack's Avatar
Blackjack
That doesn't matter.
Old Apr 3, 2010 | 02:39 PM
XSman's Avatar
XSman
Here's a pic of my wiring. Not very good though.
Old Apr 3, 2010 | 02:46 PM
XSman's Avatar
XSman
Better one from the passenger side.
Old Apr 3, 2010 | 02:59 PM
beerme986's Avatar
beerme986
everything looks correct, i assume you plugged in the original connector from the car for the fog light into the HID kit right?
Old Apr 3, 2010 | 03:04 PM
XSman's Avatar
XSman
Got them working. Reversed polarity! See:
https://www.ddmtuning.com/support/in...cleid=26&nav=0
Old Apr 3, 2010 | 03:07 PM
Blackjack's Avatar
Blackjack
Sweet! Good to know. Post pics when you get them all installed.
Old Apr 3, 2010 | 03:26 PM
downsc123's Avatar
downsc123
Had to do that as well for my ddm motorcycle kit too...
and the 2010 stock fogs are 35w not 55w as someone said above.
Old Apr 3, 2010 | 05:40 PM
2008G-Man's Avatar
2008G-Man
DC voltage is funny that way
Old Apr 3, 2010 | 05:48 PM
hispeed-lowdrag
Originally Posted by 2008G-Man
OEM is 35W...not 55W, and it wouldn't matter going to a lesser current draw if they were 55W stock, it's the other direction you have to be careful.
Isn't the OEM fog for 09's 55W? I figured they would just keep the 2010's the same
I was going off post # 2 and 4 from this thread
https://www.myg37.com/forums/body-in...ecs-sizes.html
Old Apr 3, 2010 | 05:52 PM
XSman's Avatar
XSman
Lol! I threw a code in the process. No idea what it is. Does 2010 have an OBD II port somewhere so I can scan it? Will post some pics later.
Old Apr 3, 2010 | 07:27 PM
XSman's Avatar
XSman
According to my 2010 owners manual the sedan is 35W and the coupe is 55W.
