License Plate License wont go on
Old Mar 20, 2010 | 05:53 PM
GT35R's Avatar
GT35R
I dont understand why my license plate lights do not go on. So far they are the original bulbs. I tried ever light combination on the steering wheel switch and it dont think it goes on.
Old Mar 20, 2010 | 07:26 PM
Gee37S's Avatar
Gee37S
Is it night time? Are your low beams on?
Old Mar 20, 2010 | 07:50 PM
GT35R's Avatar
GT35R
Yes and Yes
Old Mar 20, 2010 | 08:00 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
you're talking about the lights on the rear license plate? they should turn on with ANY combo of the lights being on, so basically if the **** is turned to anything but OFF (and auto during daytime) then they should be on
Old Mar 20, 2010 | 11:36 PM
2008G-Man's Avatar
2008G-Man
"So far they are the original bulbs" By this I assume you mean you haven't touched them. Do you have a volt meter? If so check for 12volts at the socket, use the ohm portion to check if the bulb is out. You can test with the trunk bulb, same type.
If you have put LED's in, they are particular about polarity, switch it around.
Old Mar 21, 2010 | 04:37 AM
AvosG37's Avatar
AvosG37
take it back to dealer!
Old Mar 21, 2010 | 11:12 AM
myk1013's Avatar
myk1013
check the bulbs, maybe burnt out.
Otherwise, bring it to the dealer.
Old Mar 21, 2010 | 12:30 PM
lakers8's Avatar
lakers8
Maybe its a fuse? Were you at 7 11 yesterday around 5 on Glenoaks?
Old Mar 21, 2010 | 03:00 PM
GT35R's Avatar
GT35R
No I wasn't. why do you ask?
Old Mar 21, 2010 | 03:10 PM
GT35R's Avatar
GT35R
I used a multimeter, It has no current in the socket.
Old Mar 21, 2010 | 04:58 PM
2008G-Man's Avatar
2008G-Man
Try the fuse .... use your same multimeter (ohms) to check for continuity through the fuse.
timc00k
Feb 15, 2017 09:15 AM
ANMVQ
Dec 8, 2016 04:55 PM
