2010 Sedan How to adjust Fog light?
Hi,
Is there a way we can adjust the fog light up a little bit on the Sedan 2010?
Also on the passenger side...how do you install the fog light...there is a window washer fluid tank there.
Thanks in advance.
DD
Thanks in advance.
DD
Thank you for that link on the 2009. I have a 2010 and the fog light is at the bottom of the front bumper. I was able to get to the fog light however i didn't see any adjustment screw.
Please advise if anyone know how to adjust it. Thank you.
I'm guessing your best bet at this point would be to call the dealer and ask, or mention it when you go in for service. If you do, please let us know, because I haven't seen anything related to this adjustment on the 2010 in the forum or elsewhere online (or in the manual).
Fog light install
I was able to install the driver side HID fog light...also from ddm. I got 3K and 8K...the 3K looks weird with greenist light...I'm going to install the 8K bulb hopefully tomorrow and will put up some pic.
I dont know how to install the passenger's drive light yet...because there is a washer fluid tank there. Probably have to remove the whole front bumper to do both light.
Anyone have link to take out the 2010 front bumper?
Thanks.
DD
Thanks.
DD
Edit: just saw you don't have HIDs in the fogs. FatboyG37S, where did you install the ballasts?
I mount the Ballast on the front bumper with double sided tape. Make sure you also mount the fire ignition to something...I left my hanging and when i go over bump it rattle with the under mount on the driver side.
I need to do the passenger side HID now. I can't get to the fog light the same way i did on the driver side. There is a tank washer fluid than on the passenger side.
Josbunjong...I remove the bottom plastic pc...however saw the tank there...what other screw do you need to remove?
*remove screws under front bumper (passenger side) and pop out black plastic under the car* And then u will c what to do.
superjoey
31
Mar 22, 2023 11:56 PM
sydnrusty
Nov 21, 2015 10:42 PM
bikerjosh
Aug 19, 2015 11:26 PM
