window not going all the way up
Old Feb 22, 2010 | 09:36 AM
Krebo's Avatar
Krebo
Is there anything i can do without going to the dealer to fix my window issue? The window will not reset itself to the correct position using the 15sec down then up rule. It stops about 1cm or less before the actual position. You dont really notice a difference at low speeds. However at 60+ mph you get a whistling noise which is starting to annoy me.
Old Feb 22, 2010 | 10:46 AM
Surfdog's Avatar
Surfdog
Hey Krebo,
Have you tried disconnecting the battery? That should "reset" the computer. We did that to my friend's M3 when his auto up/down was broken.
Old Feb 22, 2010 | 10:59 AM
Krebo's Avatar
Krebo
I will definatly give it a shot and see if it helps. Is there anything else that gets reset when disconnecting the battery?
Old Feb 22, 2010 | 11:26 AM
Xcalibur's Avatar
Xcalibur
I think the seat/rear view mirror settings get reset too.
Old Feb 22, 2010 | 02:33 PM
csnpsu's Avatar
csnpsu
When did you buy the car?
Just take it to the dealer
Old Feb 23, 2010 | 05:40 PM
Dieseldoug22's Avatar
Dieseldoug22
This is the procedure for resetting the windows form the service manual.
Initialization
Follow the steps below after installing each component to the vehicle.
1. Disconnect the minus terminal of battery or disconnect power window switch harness connector temporarily.
Then reconnect after at least 1 minute.
2. Close the door.
3. Turn ignition switch ON.
4. Operate power window switch to make over a half of the window open area.
5. Press the power window switch in the up direction (auto close position) and hold. Continue holding the
switch even when window is completely closed and then release after 3 seconds.
6. Inspect the anti-pinch system function.
NOTE:
Initialization may be cancelled with continuous opening and closing operation. In this case, initialize the system.
Old Feb 23, 2010 | 05:49 PM
JohnEnglish's Avatar
JohnEnglish
His location says Bergen and according to www.infiniti.eu there's no dealerships in Norway so I'm guessing that's why he wants to avoid taking it to the dealer.
cellwoot
Sep 7, 2018 07:10 PM
Raleclair
Oct 8, 2015 02:06 PM
RexHavoc
Oct 2, 2015 11:47 AM
CiViCKiDD
Sep 24, 2015 10:47 AM
Wreckreation
Sep 21, 2015 06:27 PM
