g37 coupe tail light removal!
Old Feb 17, 2010 | 04:20 PM
mastorian's Avatar
mastorian
Hey guys. The reason I want to remove my tail lights is to make my blinker LED. I am good with electronics so wiring in the resistor in order to not make it blink fast is easy. It is just getting to that bulb. There are 3 main screws with nuts on them. I undo all of them and I am able to push the tail light out a little bit, but it seems to be clipped from somewhere I cannot reach. I have tried everything to take the whole housing out. No luck.
If anyone knows how to remove these tail lights or has instructions.. please post!
I really appreciate it.
Thank you.
Old Feb 17, 2010 | 05:02 PM
STOOF's Avatar
STOOF
There are 2 clips on the outer edge. You can pop them out 2 ways.
either pull all the carpet back and reach all the way in and you can hit them with something to pop em out.
or just carefully tap the screw thats towards the outside with a small hammer and itll pop out.
Old Feb 17, 2010 | 05:24 PM
xlack's Avatar
xlack
unscrew the nuts, use a hammer and hit on the screws. i put some microfiber cloth over the screws and hammer it down.. worked for me.
Old Feb 18, 2010 | 04:49 PM
mastorian's Avatar
mastorian
alright guys i'll give it a go and let you know. thank you for your inputs!
*edit. thank you guys. both methods worked. greatly appreciate it.
Old Feb 19, 2010 | 05:43 PM
HenryLee's Avatar
HenryLee
you should write up a DIY>
Old Feb 19, 2010 | 06:20 PM
Ivoidwarranties's Avatar
Ivoidwarranties
There is already three different write ups on removing the tail lights.
GW330
Feb 2, 2024 05:41 PM
superjoey
31
Mar 22, 2023 11:56 PM
vquezada24
Nov 20, 2015 04:51 PM
pcwd
Aug 12, 2015 06:54 PM
