Interior Accent Lighting installed, pics.
Old Sep 5, 2009 | 10:42 PM
JKashat's Avatar
JKashat
Finally got around to install these interior accent LEDs. Install was easy but took a bit longer than expected. Probably because I kept stopping to take pics, LOL. The look good but shine far up front, like tips of your toes. Going to try and turn them the other direction as see which I prefer.
Drivers side panels removed.
Passenger side panels removed.
Another angle of the drivers side.
Another angle of the passengers side.
Drivers side hole drilled.
Drivers side hole drilled, underside.
Passenger side hole drilled. (Wrong side first, LOL)
Passenger side hole drilled. (where it was supposed to be, LOL)
LED installed on passenger side panel.
Other side of passenger side LED installed in panel.
LED installed of drivers side panel.
Other side of drivers side LED installed in panel.
Shot of jumper harness for LEDs.
Shot of jumper harness wrapped w/ supplied foam to existing harness.
Passenger side with supplied foam attaching harness to panel.
Accent lighting harness Zip-Tied to existing harness, as directed.
Passenger side, completed.
Drivers side Completed.
Hope you enjoyed!
Old Sep 5, 2009 | 11:17 PM
JKashat's Avatar
JKashat
OK, so I turned the LEDs (which are directional) the other way thinking that they'd look better and be more noticeable on the floor. Big fail. They no longer shine at the carpet but hid the front of the seat on the thigh extension of my Sport Seats. I will get under there and twist them back tomorrow. My neighbors think I'm weird for how much time I spend in the garage messing w/ my car, LOL.
Old Sep 6, 2009 | 01:53 PM
]\[ /-\ ]\/['s Avatar
sweet!
my ghetto-rigged accent lighting turned out to be too bright for my taste
Old Sep 7, 2009 | 04:34 AM
BradManUWF's Avatar
BradManUWF
I like mine, they look great. I went with the OEM kit because I knew just buying some LEDs and wires would be too bright and/or not match the LED that's already next to the map lights. Install took a little longer than I expected as well, but most likely due to taking my time and trying to not break anything.
Old Sep 7, 2009 | 09:30 AM
DrJones's Avatar
DrJones
thanks for the post. I was considering doing this.
Old Sep 8, 2009 | 06:36 AM
Blackjack's Avatar
Blackjack
Get some better pics showing the full interior.
Old Sep 8, 2009 | 11:50 AM
The Jewbag's Avatar
The Jewbag
I was told that the Infiniti accessory accent lighting is junk. I'm going to have a local shop install something better.
Old Sep 8, 2009 | 12:12 PM
JKashat's Avatar
JKashat
I wouldn't by any means say they were junk, just that w/ the 180 degree beam pattern pointed forward (according to the directions) that not enough light is directed at the floor. It's more directed at your toes. Quality of the kit is great and it is plug and play, not tapping or splicing. Only this I wish was different was the beam pattern should have been 360 degrees.
Old Sep 8, 2009 | 12:36 PM
lakers8's Avatar
lakers8
Get some pictures showing your seat and carpet
Old Sep 8, 2009 | 10:40 PM
TomieG's Avatar
TomieG
^And on at night.
Old Sep 9, 2009 | 01:50 AM
BradManUWF's Avatar
BradManUWF
That's why they call it "Accent Lighting", not "Floor Illunination". It just supposed to put a nice glow on the floor board, not light up the whole thing so you can conduct a Search & Rescue Mission in the front seats. I think it's the perfect amount of light. Puts that nice glow on the floor that isn't too bright, but bright enough to add that little something extra to the interior at night.
Old Sep 9, 2009 | 02:18 AM
ElLayG37s's Avatar
ElLayG37s
better photos please, can't tell what I'm looking at.
Old Sep 14, 2009 | 10:09 PM
JKashat's Avatar
JKashat
More shots, they don't show up well on camera.
Old Sep 15, 2009 | 08:00 AM
myk1013's Avatar
myk1013
** mYK likes this!
superjoey
31
Mar 22, 2023 11:56 PM
cparise
Aug 19, 2015 01:51 PM
Upscale Speed
Aug 6, 2015 04:08 PM
